Bronco II Ford Bronco II
Will these fit?
Old Jul 18, 2009 | 11:06 AM
kenpobuck's Avatar
kenpobuck
Will these fit?
My duaghter has an 86 BII and the doors are rotted out bad. I have found a set of doors that are on a 92 ranger. I know they don't have the vent windows on them but will they fit her truck? I can get them cheap ($100-120). Also, is there a difference between the stick and auto tranny starters on the 2.9Ls?
Old Jul 18, 2009 | 12:23 PM
Eddiec1564's Avatar
Eddiec1564
I think the Ranger doors are little smaller than the Bronco2 doors. Better measure before buying them. Not sure on the starter, I'd call up a few part houses and ask them for a starter for both manual and automatic to see if there is a diffrance.
Old Jul 18, 2009 | 06:40 PM
idfergusson's Avatar
idfergusson
My LMC truck catalog shows the same part number for the doors for 84-88 Rangers,Bronco II's and another number for 89-92 Rangers and 89-90 Bronco II's.I put the door panels from a 91 Ranger ext cab into 84 Bronco II and they fit fine except for a bracket I had to transfer over so they are the same size.The LMC catalog lists a different window for 84-88 and 89-90 so the door differences are probably related to that as most of the other parts appear to interchange.
Old Jul 18, 2009 | 09:37 PM
kenpobuck's Avatar
kenpobuck
Thanks for the info guys, I will just have to try them.
Old Jul 18, 2009 | 09:47 PM
rebocardo's Avatar
rebocardo
92 Ranger doors will not fit a 86 B2. At a min. the creases and such will be different. 1992 latch system is different too.
f100today
Jul 4, 2016 10:10 AM
67highboy
Mar 17, 2016 02:56 PM
0500757Arf
19
Nov 1, 2015 07:19 AM
Glxy66
Sep 16, 2015 01:29 AM
