Remote Start - Plug and Play??
Old Jul 17, 2009 | 09:31 PM
saride's Avatar
saride
I want to add the remote start to my 08 F150 5.4. Does anyone know if there is an easy plug and play ford part # that I can install?
Old Jul 18, 2009 | 06:36 AM
svt2205's Avatar
svt2205
Ford's remote start kits require use of their wiring kit. Here's one I found on ebay that the seller said was for his 07. Not suggesting that you buy this or that it is the right one for your truck, but I am suggesting you look at the pics.
http://cgi.ebay.com/ebaymotors/07-08...Q5fAccessories
In this listing you can see the harness with some plugs. I believe there is a fair amount of splicing that must be done to install the kit.
So the short version, is Ford doesn't sell a plug and play remote starter kit.
I had looked into the idea of installing one, but when I learned of the splicing required, I said, it's not worth the hassle.
Old Jul 18, 2009 | 02:48 PM
bridge's Avatar
bridge
Sick 'n Tired
There is no plug-n-play remote start system for our trucks, for all models you will have to do some splicing. How much depends on the unit you get; if it is just a remote start or if it also serves as a security system as well.
It is a difficult job even if you've got experience installing electronics in cars. It would be a PITA if you are a novice.
Old Jul 18, 2009 | 08:46 PM
Greg B's Avatar
Greg B
It can cause enough problems with the passive anttheft system that I don't think I'll be looking into one. Even if it were a plug and play I don't think I'd bother.
Old Jul 18, 2009 | 08:51 PM
ford390gashog's Avatar
ford390gashog
Word to the wise having done 3 of these installs now with the ford kit it is a huge PITA. The amount of cutting and splicing is crazy its not plug and play. It took me darn near 9 hours to do the first one then about 4 hours on the other 2.
Old Jul 18, 2009 | 09:18 PM
bridge's Avatar
bridge
Sick 'n Tired
Just my 2 cents...while a PITA to install, I've had remote start on all my ford trucks since '01 and I've never had any problems with the stock passive system.
Old Jul 18, 2009 | 09:49 PM
Twinsdad98's Avatar
Twinsdad98
I second with Bridge. I have the ford system on my 2004 F150 and have never had a problem with it or the PATS. I wouldn't want a vehicle without a remote start.
Old Jul 19, 2009 | 06:22 PM
mattd17's Avatar
mattd17
i agree.... remote starting units are great.... yes, they can be time consumin to install, but of the 10 that i have done on various models of cars/trucks, not one has been a PITA. its all about pain vs. gain in my mind. ill gladly spend a day to install a unit to reap the benefits down the road.
i am a big fan of crimestopper units. not the alarms, just the remote starter/keyless entry units. i average about 10 hours on my installs... i solder all connections, and make it look as close to stock as i can. remember, it doenst matter how much money you spend on a unit, it will only be as good as the install job. the features they come with these days in amazing. they no longer require a spare key to be "hidden" under the dash for the PATS system. once the modules are programmed, your all set to go.
if your looking for a basic system, they really dont require that much splicing. to get a basic starter/keyless entry unit, you will be looking at around 15 wires (depending on features/brand/etc), maybe more, maybe less.
long story short, if you decide to go for it, there are plenty of people here that can provide help if you get stuck. in fact, im doing on this coming wednesday for a friend.
plus, its pretty cool to be able to start your truck from several hundred yards away so its warmed up and ready in the winter !!!
Old Jul 19, 2009 | 08:15 PM
saride's Avatar
saride
Well I plan on buying a unit, either oem or aftermarket in the next week or two and I will probably get stuck some where along the way so any help offered is appreciated.
Old Jul 20, 2009 | 04:32 AM
ford390gashog
Go aftermarket! The stock system is good if it came with the truck but other than that no I would not install the oem one. The oem system when installed after the fact can disable the PATS system this is why I reprogram them before letting it leave the shop.
Old Jul 20, 2009 | 04:42 AM
James_24_85's Avatar
James_24_85
I consider myself to be pretty good at installing electronics. I have more gadgets then a space ship in my truck. But the one thing I gave up on was the remote starter. I eventually had a shop do it. Cost about 300 bucks with all the equipment. My only regret is mine is a single button so I have three fobs on my key chain one for remote start one keyless entry one for the alarm on my harley. My starter does reach from half a mile away which is pretty cool though.
snelldawg
Dec 23, 2016 09:33 AM
chaostoday
Escape & Escape Hybrid
Dec 18, 2016 11:17 AM
BeefyII
Dec 5, 2016 06:52 PM
Gotsmoke12
6.7L Power Stroke Diesel
Dec 31, 2015 07:31 AM
rydeyz
2009 - 2014 F150
Apr 1, 2011 11:26 AM
