Odd Deceleration
Old Jul 17, 2009 | 08:58 PM
acpchuck's Avatar
acpchuck
Odd Deceleration
I have a '94 F150 with the 5.0 V8, 5 speed and 4 WD. I drive about 12 miles to work with the middle section being freeway speeds. When I take my foot off the gas at the exit ramp the truck will start to slow and then about 5 to 10 seconds later there is kind of a jerk and the engine acts likes that is when I took my foot off the gas. Kind of hard to explain, the truck is slowing but it like the first part is just a partial throttle release then 5 to10 seconds later a full release.
Truck runs fine, fairly recent tune up. Adjusted the timing (still doing it), no service engine light on. Gas mileage is good. Cable to intake system working fine. Have had this truck for about 3 years and it has always done this. Not really a problem just weird. It does not do it at lower speeds even in the same RPM range of coming off the freeway.
Any ideas why it does this?
Old Jul 17, 2009 | 09:10 PM
93 mix 'n match's Avatar
93 mix 'n match
does it do it anywhere else? or just on that particular exit?
DBGrif91's Avatar
DBGrif91
Check the throttle position sensor- I'm not sure of the exact procedure, but if you have a service manual it can tell you how.
Old Jul 17, 2009 | 10:57 PM
acpchuck's Avatar
acpchuck
Does the same thing on the way home. Outside temp doesn't matter. 95 degrees today. Does it in the winter at 10 degrees.
Will take a look at the throttle position sensor to see if that is the culprit.
Old Jul 19, 2009 | 08:49 AM
EPNCSU2006's Avatar
EPNCSU2006
I believe that is the overrun fuel cut -- my truck does that too. Best I can tell, it is when the injectors turn off completely while coasting to increase fuel mileage. I don't think anything is wrong with your truck.
Old Jul 19, 2009 | 03:41 PM
McLeod's Avatar
McLeod
Mine does that too.
I always thought it was the torque converter coming out of lock up.
**Edit
I just noticed that you have a 5 speed. Nevermind...
Old Jul 19, 2009 | 05:38 PM
frankyford's Avatar
frankyford
Hey, if you change the TPS have fun and when you remove the TB to get to it, check inside your upper intake plenum for carbon build up. If you clean it out make sure you have a shop-vac handy so no peices go into the lower intake or the engine
Golden Helmet
21
Sep 29, 2013 10:09 AM
Pool Runner
2009 - 2014 F150
47
Jun 12, 2012 11:11 AM
need4spd
Jan 7, 2009 02:58 AM
cigarxtc
Mar 21, 2005 04:54 PM
willystyle21
1978 - 1996 Big Bronco
17
Jan 25, 2004 12:50 AM
