need break help
Old Jul 16, 2009 | 07:00 PM
troubleinnc2's Avatar
troubleinnc2
need break help
i bought a 73 f100 302 it has man. breaks it has been sitting since about 1996 im going through the breaks i had to keep pumping the breaks and still dont have good breaks so i replaced the mc and it got worse so i returned the mc and got another one its still doing the same i have to pump the breaks about 10-15 times to stop so i blew the lines out took the prop valve off took apart cleaned still no fluid to back wheels and still no breaks so i got another prop valve still same thing any help will be great
Old Jul 16, 2009 | 07:56 PM
a truck named effy's Avatar
a truck named effy
Only thing that comes to mind is a pin hole in the line, or your flex lines have a lot of stretch in them. How old are the flexible lines that run to the calipers on the front breaks? Did you say no fluid is getting to the back wheels even with a new prop valve?
Old Jul 16, 2009 | 09:11 PM
4x4 Bart's Avatar
4x4 Bart
Did you bench bleed the MC before you put it on?
Old Jul 16, 2009 | 09:18 PM
cgfirefighter's Avatar
cgfirefighter
I have the same exact problem and its been eating at me for a while. I have replaced just about everything in the BRAKE system including blowing out all the lines as well as a few new ones. I also have tried different brake valves and I still can't get brake fluid to the rear wheels for the life of me!
Old Jul 16, 2009 | 09:50 PM
fmc400's Avatar
fmc400
MSEE
I was going to ask the same thing.
Old Jul 16, 2009 | 10:51 PM
cgfirefighter
I did, and I even had the same problem before I put a new MC on it.
Old Jul 16, 2009 | 11:02 PM
shadowviper12345's Avatar
shadowviper12345
are the front brakes working? i dont mean to be rude but its getting on my nerves, its spelled brake not break.
Old Jul 16, 2009 | 11:19 PM
cgfirefighter
I hate to steal troubles thread, but on mine I can get fluid to the front just fine. (I know, thats why I spelled brake in all caps earlier )
Old Jul 16, 2009 | 11:45 PM
shadowviper12345
is the m/c holding fluid in the rear brake reservoir? or does it jut leak out when you push on the brake pedal?
Old Jul 16, 2009 | 11:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Adjust your rear drum brakes. If they are really slack then it's going to take quite a few pumps to take up the slack. Even an 1/8" gap can take a bit to make them work.
Adjust the drums so there is a slight drag.
Josh
Old Jul 16, 2009 | 11:51 PM
Furyus1's Avatar
Furyus1
I seem to recall reading somewhere where someone had taken a extra fluid reservoir cap and fitted it with an air fitting so a tire pump could be attached to it - he then used the tire pump to "pressure bleed" the brakes from the reservoir down. Once done, he put the original reservoir cap back on. I've done something similar with the hydraulic clutch on a Saab 900 which worked beautifully and didn't require modifying the reservoir - just needed a bicycle innertube and a hose clamp...
Old Jul 16, 2009 | 11:56 PM
shadowviper12345
brilliant. i'll have to try that
Old Jul 17, 2009 | 12:53 AM
bmuhlbach's Avatar
bmuhlbach
when you put the m/c on it should slide back againest the booster( i am assumeing there power brakes)if it doesn't you will need to adjust the push rod to make it shorter.if it is preloaded it will push the plunger in the m/c and rear brakes would be effected.
Old Jul 17, 2009 | 01:32 AM
Tees77f150's Avatar
Tees77f150
THANK YOU FOR MENTIONING THAT! I don't mean to be rude either, but it was driving me nuts to read it that way, and good luck with your brake issue!!
Old Jul 17, 2009 | 03:07 PM
Bullitt390's Avatar
Bullitt390
I'll repeat it again, the rear brakes HAVE to be adjusted for the brake pedal to be correct.
Josh
