I have been having trouble with my 2002 F250 SD, the steering at low RPM is next to impossible.. If i put it into N I can rev the engine and it gets "easier" but not very. has anyone seen this problem? I do not want to replace the pump and find out that it wasnt the problem
My steering was difficult at a stop. A simple fluid flush has me spinning the wheels with ease. A couple qts of ATF and an hour to flush out the old fluid would be where I started. If the pump isn't whining all the time, then it's probably working.
I am a new and my steering whines when I am parked and make sharp turns. Could this be the pump?
Thanks
Gil
The most likely cause is dirty Mercon V in the power steering pump system, air infiltration into the system, or bad pump. Start cheap on the fixes, check the hoses and connections to and from the pump, hydroboost, cooler and steering rack for tightness, cracks, or leaks. Check hoses for age related failure. Next flush the system (directions at link above). Then, if that doesn't fix it, replace the pump and flush again.
TIP: The PS system should be filtered (magnafine filter). Put one in after flushing the system.
My truch steering has been humming for about two years. Did a flush and seem to be OK, in the winter. but as it got warmer it started again. sooo Ford installed a new pump and flush " come and get it its fixed", It did the same thing thing as I drove out of the shop Also when i stop and go a clunk happens greased the slip joint yoke seemed to be a little better ???
I checked under the hood and in the center there is a wire not connected ??
I have the same problem. I did replace the pump several years ago. Did you ever find the cause?
