Dead Battery Q
Old Jul 16, 2009 | 11:41 AM
qman's Avatar
qman
Dead Battery Q
The kids like to leave the interior lights on in my rig (not my truck) and kill my battery. I took it in to AZ to have them test it and the guy puts it on his tester which tells him to charge it first. When he puts it on the charger the voltage is real low or something and instead of charging it he tells me that it's dead since the voltage is below 12. Isn't that what happens when you leave the lights on, the voltage drops?
I have the feeling he just wanted to sell me a battery instead of charging it and putting it back on the tester. Am I being paranoid?
Old Jul 16, 2009 | 01:54 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You found a real old timey salesman. Screw the future...sell for today! Get it re-charged and put it back in the truck.... keep the kids out of it! hehehe
Old Jul 16, 2009 | 02:11 PM
Franklin2's Avatar
Franklin2
If you have other symptoms, then yes I would get a new battery. The voltage should not go below 12v unless a load is put on it. With it just sitting there, putting a voltmeter on it should give you around 12v. If you get 10 or less, then the battery is bad.
Now if he had one of those load testers with the resistors in it, then yes the voltage would drop below 12v if the battery is just discharged, and the battery still may be good.
If you have run this battery down like this more than 2 or 3 times, then a new battery is not going to be a waste of money. These batteries are starting batteries, not deep cycle. They are not designed to be run completely down and re-charged, and can be permanently damaged.
So if you are having problems with starting, besides leaving the lights on, the battery may be ruined.
Old Jul 16, 2009 | 02:43 PM
qman's Avatar
qman
Thanks guys, that's the kind of info I'm lookin for.
BTW, what do you mean "other symptoms?"
Old Jul 16, 2009 | 03:37 PM
qman's Avatar
qman
Anyone ever heard of this?
http://www.battery-rechargeable-char...ife-saver.html
If so does it work?
Old Jul 17, 2009 | 09:24 PM
Franklin2's Avatar
Franklin2
What I was thinking was if the only problem you have is the truck not starting after the lights were left on, then the battery is probably good. If after charging the battery you are getting slower cranking, or no crank at all, then a new battery may be needed.
Old Jul 18, 2009 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
If so does it work?
the link is no good.
gumbydamit
Electrical Systems/Wiring
13
Dec 22, 2021 08:45 AM
Smirks90
13
Nov 1, 2014 05:11 PM
CaptKen
May 6, 2013 02:13 PM
qman
16
Jul 16, 2009 09:19 PM
smashing4455
Aug 16, 2004 12:00 AM
