Intermittent Wiper conversion?
Old May 24, 2009 | 08:40 PM
80s Trucker's Avatar
80s Trucker
Question Intermittent Wiper conversion?
I have a 1990 F150 with the standard two speed wipers.
I would like to convert the wipers to intermittent wipers.
I assume it is more that just replacing the switch?
Any help would be greatly appreciated.
Thanks
Old May 24, 2009 | 09:42 PM
Franklin2's Avatar
Franklin2
That's all there is to it. Go to the junkyard and get the switch AND the module that the wiring from the switch plugs into, and plug it into your truck.
Old May 25, 2009 | 03:04 PM
2000Ford2000's Avatar
2000Ford2000
Ya. I swapped my 89 van and 88 RV module to get intermittent in the RV. There is an extra box that comes along with the intermittent module. It was dumb to not have intermittent in a Class C motorhome with the overhang.
Old May 25, 2009 | 08:55 PM
80s Trucker
Thank You Franklin2 & 2000Ford2000, you have been very helpful.
Old Jun 19, 2009 | 07:49 PM
Old Brown Truck's Avatar
Old Brown Truck
Module? LOL I got an intermittent switch, it fits my wiring in both my 76 and my 79 but only will make my wipers go to high speed. What and where is the module I need?
Old Jun 19, 2009 | 09:13 PM
Franklin2's Avatar
Franklin2
Follow the wiring in the junkyard truck from the intermittent style wiper switch and you will run into it.
Old Jul 6, 2009 | 10:25 PM
Old Brown Truck
I'm puzzled. I purchased an intermintent switch w/ a module and harness on E-bay. It won't do anything in either my 76 or 79. Only high works. Occasionally a single pulse in what I would have thought was the Off position. I'm seeing references to a cold solder in the control module box. I can easily get into the control module. Any tests I can do to see if the module is faultly? One thing I notice is that a blade that is associated with the washer motor is missing on the harness I got. Not surprisingly pushing the switch isn't triggering the washer motor.
Old Jul 7, 2009 | 09:14 AM
Franklin2's Avatar
Franklin2
Are you turning it to the left for intermittent? Center is off. To the right is low and high. I am not sure this is plug and play on the earlier trucks. I know it is on the 80-up trucks.
Old Jul 7, 2009 | 06:17 PM
Old Brown Truck
I lose low speed, and occasionally I get a single swipe I think at "off" or the very beginning of intermittent.
The intermintent switch has a separate ground wire, that the regular switch doesn't have. My 76 and 79 look the same. The wiring into the switch is two parts that nest into the switch. One part only has two blades and seems to control the washer motor, the other part has 5 or 6 blades. I notice that on the intermintent switch, that one of the blades that would have gone to the washer motor isn't in the harness, the slot is there, but no blade/receptacle and the intermintent switch won't control the washer motor. So? I need a 78-79 intermintent switch/modulator box? Or there the modulator has a piece that is burnt out? I thought that I could do this with a pre 80.
Old Jul 18, 2009 | 08:23 AM
tjc transport's Avatar
tjc transport
i ain't rite
to get the washers to work with the newer switch module combo you will need to switch a couple of wires around.
i have mid 80's modules and switches in both my 79 F250 and 65 falcon. unfortunatly, it was done years ago, and i dont remember what wires need changing any more.
kjay
36
Oct 23, 2019 12:38 PM
Shadowrider123
Dec 31, 2014 05:05 AM
Blue and White
Jan 1, 2012 05:34 PM
ZukBox II
Oct 11, 2010 03:01 AM
earnies2
Electrical Systems/Wiring
Mar 20, 2006 08:48 AM
