Hey ranger guys, have quick question to maybe help figure something out on a buddies truck, if he leaves his 1994 ford ranger 2.3 out in the sun and the truck gets hot from the outside temp. it wont start, but in the morning or evening when not so hot it will start just fine, ive never had a problem like this before. any ideas?
Thats what i told, but these condos are sparting up like weeds here in austin, and dude had to go off and live in one of those, so his garage at best is an oak tree by the front door. From what ive seen and heard is it sounds like its not getting gas, but *** soon as sun goes down or it gets cooler, starts right back up like nothin, just the wierdest thing to me. ive tried starting fluid and nothing, checked all caps and fuses, but still nothin either w that approach.
I once had a somewhat similar problem with a different car, but it wasn't caused by the sun.
The car would start, run for a while, and then stall.
My then-mechanic traced the problem to a corroded electrical connection. If I recall correctly (this was nearly 25 years ago), it was the coil wire. There was a brass-like ring inside of a rubber boot that had gotten corroded, and when it heated, the metal expanded and broke the connection.
The problem totally stumped my grandfather, who was a pretty solid mechanic himself.
something I just found yesterday: Vapor lock on boy's friend's 94. at 1/4 full tank or less you start sucking air into the fuel, and at about 90 or so degrees you are no longer getting enough fuel to run. a sack of ice applied to the fuel regulator and anywhere on the engine top that will hold it cooled it enough to run fine again. runs good @ over 1/4 tank, probably since there is enough mass in the tank to not get much above ambient.
