Another tranny flush thread...
Old Jul 17, 2009 | 08:17 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
I would do the following:
1) Drop pan and change internal filter (look at fluid color and any residue in pan to see if any problems are evident?
2) Change the external by-pass tranny filter.
3) Drive for 10,000 miles or so (no real perfect number here).
4) Do the tranny flush and change the by-pass filter again.
I think you will be good to go to get back on a regular service interval of 30,000 miles.
What do you think???
Old Jul 17, 2009 | 08:33 AM
juneau76's Avatar
juneau76
Ok, I may be a little bit stupid, but when I had my tranny flushed they dropped the pan and changed the screen as part of that service. I guess I'm missing something here in that they don't do that as a normal tranny flush.
Old Jul 17, 2009 | 08:41 AM
Beachbumcook
Got Diesel?
There are two types of tranny services available:
1) Drain and refill (drop pan, change internal filter and refill with fluid).
2) Flush - which is hooking up your tranny to a machine filled with the Mercon SP and when started and worked through the gears, the new fluid is sucked in and the old fluid is pushed out and collected. You now get a 100% fluid exchange where as the drain and refill is only about 1/2 (as 1/2 stays in the convertor).
You always have to ask about the external by-pass filter as not all dealerships change this out as part of any of their servcies and if the technician is not used to working on a 6.0L, he may not even be aware of it.
I always have the external by-pass filter change at every service regardless.
