Modular V10 (6.8l)
F450 no start
Old Jul 15, 2009 | 02:17 AM
bajhafords's Avatar
bajhafords
F450 no start
Hey guys my friends got an F450 service truck with a V10 and it died while it was idling yesterday and wouldn't start. Check the fuel pressure and it has 45 psi. 20 minutes later fired right up and run for about 5 seconds and died like you shut the key off. Now won't start at all. Hooked up my snap on scanner and for some reason it won't communicate with it. Kinda hard to diagnose with no codes. Grrrr... any ideas? Seems to hit off of carb cleaner
Old Jul 15, 2009 | 01:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check the cigarette lighter fuse, if that's blown, the OBD-II won't communicate.
Does the check engine light come on when you first turn the key to ON?
Old Jul 15, 2009 | 08:38 PM
Fordfanatic4life's Avatar
Fordfanatic4life
does it still have fuel pressure ???
thinking fuel pump, but if ur still getting pressure and it wont run that kind of kills that idea...
Old Jul 16, 2009 | 02:13 AM
bajhafords's Avatar
bajhafords
Already checked the cigarette fuse it was fine and getting power. Check engine light is on when you turn the key on, what does that mean? Checked all fuses and swap some relays still no go. I suppose I'll get a schematic tomorrow and see why the hell my scanner wont work. Just to make sure tried my brother's 01 V10 and the scanner works fine so I'm pretty sure it's not it. Tried cracking the throttle a little bit still the same.
Old Jul 16, 2009 | 12:01 PM
krewat's Avatar
krewat
The check engine light coming on means the PCM has power.
You need to check for injector pulses, and COP fires (spark).
Sounds like the crank sensor, but who knows.
ssnbdr75
Apr 27, 2012 10:39 PM
chopman
Jun 23, 2011 06:52 PM
Justinedgerton
Apr 27, 2010 08:27 PM
chesshircats2
Nov 8, 2009 12:36 AM
holiday187
Aug 6, 2007 08:38 PM
