Dashboard Switches
Old Jul 14, 2009 | 11:11 PM
JefflovesF250s's Avatar
JefflovesF250s
Dashboard Switches
All: Have successfully removed all the switches except the one with the un-marked bezel 2nd from right of the steering column. What is this switch for and how does it come off the dash? Did manage to remove elec. connection from rear but switch a mystery!
Oh by the way I have a '66 Custom Cab F250.
Thx for your advice. Jeff
Old Jul 15, 2009 | 02:27 AM
camperspecial65's Avatar
camperspecial65
which switch...I sent you pics of layout of mine a long time ago...in case you happen to have them...The switch is the 4 way flasher switch...the bezel screws onto the switch itself...if you rotate the switch slightly one way and hold the bezel as you do it it will start to loosen...If you need any other pointers, give a call...btw...I got the t/gate apart...looking really good...amazing what a thorough cleaning can do...
- cs65
Old Jul 15, 2009 | 09:44 AM
JefflovesF250s
CS: Thx. That should do it. Don't recall the photo you mentioned or the tailgate. Thx again for the switch hint. Jeff
Jeff Hildreth
Jul 8, 2013 07:33 PM
jeff14346
Mar 9, 2012 09:01 AM
bigblockford_390
Nov 4, 2011 11:26 PM
luvmyaussy
Sep 6, 2005 08:03 AM
jeff_67cougar
Aerostar
Sep 9, 2002 06:03 AM
