X Code Question
Old Jul 14, 2009 | 10:36 PM
megawatt00's Avatar
megawatt00
X Code Question
Chris (That-Guy) has hooked me up with a set of X Codes for the front of my truck. Thank You Chris!!!!!
How much lift can I expect from these? Will they level my truck? I have heard everthing between 1"-3".
Thanks
Old Jul 14, 2009 | 10:43 PM
bdrummonds's Avatar
bdrummonds
2 to 2.5 inches of lift depending on what your original spring code is.
from my archives
There is a two-character spring code on the vehicle certification sticker on the lower doorpost behind the driver's door. The first character is the front spring code, and the second character is the rear spring code. A common spring code for a CrewCab 4x4 would be VB. The V means 5,200 pounds front springs, and the B usually means the rear springs on an F-350 SRW. However, some F-250s also have code B rear springs.
Any pickup can have any available front spring code - depending on options, and it doesn't matter whether F-250, F-350 SRW or F-350 DRW. Here are the spring codes for the front leaf springs on '99 thru '04 PSD 4x4 pickups:
T = 4,400 pounds @ground
U = 4,800
V = 5,200
W = 5,600 (rare on a pickup)
X = 6,000 (only with snow-plow pkg on a pickup)
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
If you already have code B rear springs, then you already have the same rear springs that are on F-350 SRWs.
If you have Code U or V front springs, then you might like the code X front springs. In addition to giving you a little more weight capacity on the front end, they will give you a one to two inch lift of the front end.
If you wanted to really beef up the springs on your F-250, then put the code X front springs and the code C rear springs on it (they should bolt on). But be warmed it will then ride "like a truck".
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 212.25pt; HEIGHT: 68.25pt" type="#_x0000_t75"><v:imagedata o:title="" src="file:///C:\DOCUME~1\BRANDO~1\LOCALS~1\Temp\msohtml1\01\cli p_image001.wmz"></v:imagedata></v:shape>
Old Jul 14, 2009 | 10:47 PM
big poppa's Avatar
big poppa
Great info Brandon, never seen this before... Reps also sent...
Old Jul 14, 2009 | 10:56 PM
megawatt00's Avatar
megawatt00
Great info Brandon I will check what I have in the morning. Reps sent
Old Jul 14, 2009 | 11:03 PM
jhand124's Avatar
jhand124
Jim, I got a good 2" of lift from my original worn out v-codes. My 285's were rubbing on the fender wells before I changed to x-codes.
Old Jul 14, 2009 | 11:08 PM
megawatt00's Avatar
megawatt00
I'm wondering now if I have V codes on there now where it is a dually. I going for the flashlight now......
Old Jul 14, 2009 | 11:14 PM
jhand124's Avatar
jhand124
The odds are pretty good, I think.
Old Jul 14, 2009 | 11:16 PM
megawatt00's Avatar
megawatt00
Your right Jason V in the front C in the rear.
How is the ride with them?
Old Jul 14, 2009 | 11:23 PM
jhand124's Avatar
jhand124
I actually like the ride better, little more firm but not like a hay wagon. I think I gained a little more stability from the x-codes too. Your drw would already be more stable, so I don't know if you will notice that. I think with a long wheel base x-codes ride better than v-codes. Now if you had a standard cab it would ride horrible, I know I have ridden in one. I think you will like them.
Old Jul 14, 2009 | 11:34 PM
megawatt00's Avatar
megawatt00
I guess that I will be all set a long bed with the extended cab. Thanks again Reps sent to you for the info
Old Jul 14, 2009 | 11:45 PM
superduty4x4's Avatar
superduty4x4
Nice score Jim! I'll have to rep That_Guy when I see him next.
Old Jul 14, 2009 | 11:50 PM
That_Guy's Avatar
That_Guy
Thanks
No problem man, They are just sitting in my garage and you said you needed them so there yours.
Old Jul 15, 2009 | 12:59 AM
big poppa's Avatar
big poppa
Can't rep you for the nice gesture Chris but I'll throw one your way when I can...
Old Jul 15, 2009 | 06:43 AM
Neal 97 250's Avatar
Neal 97 250
Great info. Reps sent to those I could.
Hopefully the spring swap will continue...
Muuuhahaha
Old Jul 15, 2009 | 08:38 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
anyone else got a set of x codes laying around they dont want? ive been looking for a set for like a year and have never been able to find some. every time i hit up the pic-a-part or a different junkyard thats the first thing i look for..........
