Fluid Amount in a Torque Converter?
Old Feb 5, 2001 | 01:57 PM
mudslinger_82's Avatar
mudslinger_82
How much fluid should I put in my torque converter????
[center]
[font color="blue"]
Mudslinger_82 aka Mike G
[/font]
[link:ford-trucks.com/pictorial/big/1982_f150_a.html"|Here's the Pic's of Mudslinger]
http://farmall_h.tripod.com/tractors_files/Animated/257.gif
[font color="red"]
[marquee]Ford Power All The Way, If it ain't broke don't fix it.[/marquee]
[/font]
Old Feb 5, 2001 | 06:06 PM
billyb's Avatar
billyb
Old Feb 5, 2001 | 11:57 PM
oz9609's Avatar
oz9609
Is the T/C out. Is it in but drained. Need more info.
Old Feb 6, 2001 | 12:51 AM
mudslinger_82
In middle of engine swap its back in and drained and has a quart of ATF back in it......just not sure about the sure amount....
[center]
[font color="blue"]
[/font]
[font color="red"]
[/font]
Old Feb 6, 2001 | 09:28 AM
oz9609's Avatar
oz9609
That's what I needed to know. If the tranny is empty then you need to put 4 qts in it and start it. Add about 4 more qts. and check it. Add and check till it is at the proper level. Don't add more than 4 qts. without starting or it will run out the vent tube. Let me know if you have any more questions.
Old Feb 6, 2001 | 02:04 PM
mudslinger_82
Ok are we talking about the tranny fluid. I am talking just about the Torque Converter itself. ?
[center]
[font color="blue"]
[/font]
[font color="red"]
[/font]
Old Feb 6, 2001 | 04:17 PM
oz9609's Avatar
oz9609
The converter fills from the pan with the engine running. there is no way to know how much until you fill it to the proper level.
Old Feb 6, 2001 | 06:37 PM
mudslinger_82
I am correct though that you do have to drain it seperately correct....
[center]
[font color="blue"]
[/font]
[font color="red"]
[/font]
Old Feb 6, 2001 | 07:10 PM
oz9609's Avatar
oz9609
Yes. There is a drain plug next to one of the studs on the flywheel side.
mudslinger_82
Apr 28, 2001 05:15 PM
mudslinger_82
17
Apr 2, 2001 11:16 PM
mudslinger_82
Feb 14, 2001 09:15 PM
mudslinger_82
Feb 14, 2001 08:56 PM
mudslinger_82
Feb 12, 2001 11:54 AM
