Won't start-more information
Old Jul 14, 2009 | 01:46 PM
John52's Avatar
John52
I have a 03 F250 with 50,000 miles on it. This is my first diesel. It has ran fine have put over 5k miles on it. Went out this am to move it and it wouldn't start. Turns over fine, oil is fine, check engine lite stays on, glow plug lites go out-just turns over with no indication on the tach. I replaced the CPS still no start. I've checked the fuel pump this is ok-putting out fuel. I've swapped the Injector driver module relay with another and it continues to keep clicking. If I remove the Powertrain EEC relay it stops clicking and starts clicking again as soon as I put the Powertrain EEC relay back in. I am lost. Please help me, I suppose to leave on a trip tomorrow morning. Thanks
Old Jul 14, 2009 | 02:03 PM
tdpower's Avatar
tdpower
Sounds like bad batteries. Summer heat will take its toll on them. Could also be dirty/corroded terminals. I would also check to make sure your alternator is working properly especially if you plan on a trip.
Old Jul 14, 2009 | 03:56 PM
John52's Avatar
John52
Just went and good new batteries still will not start. Cables are clean also.
Old Jul 15, 2009 | 12:15 AM
4inchlovin's Avatar
4inchlovin
Did you check the oil level in your HPOP? If she is turning over fine but not firing it sounds like a lack of oil pressure to me...
Old Jul 15, 2009 | 10:00 AM
Action4478's Avatar
Action4478
Make sure the wiring to the PCM is clean & tight . Have you checked all the fuses ?.
Are you using a chip ?, if so may need to remove it ..(Keys in your pocket)...
Old Jul 15, 2009 | 10:08 AM
03_PSD's Avatar
03_PSD
I have had similar problems and it turned out it was a icp wire fraying promble.
perry_bush
Oct 26, 2017 02:46 AM
HD
13
Jan 9, 2016 07:05 AM
HarmonyHollow
Sep 29, 2014 09:09 PM
White Mountain Goat
13
Jun 11, 2014 03:08 PM
Harlakijn
1978 - 1996 Big Bronco
Aug 16, 2013 12:15 AM
