Won't start
Old Jul 14, 2009 | 10:50 AM
John52's Avatar
John52
Won't start
I have a 03 F250 with 50,000 miles on it. This is my first diesel. It has ran fine have put over 5k miles on it. Went out this am to move it and it wouldn't start. Turns over fine, oil is fine, check engine lite stays on, glow plug lites go out-just turns over. I replaced the CPS still no start. Please help me, I suppose to leave on a trip tomorrow morning. Thanks
Old Jul 14, 2009 | 10:54 AM
F350-6's Avatar
F350-6
Welcome to FTE. Any smoke out the tailpipe while cranking? When's the last time you drove it? If your batteries are too weak it will spin the motor fine, but won't provide enough voltage to fire the injectors.
Also where did you get the CPS from? Some of the ones from the parts stores have been known to be bad out of the box.
Old Jul 14, 2009 | 10:57 AM
John52's Avatar
John52
Thanks
I will turn it over and have I wife check the tailpipe when she gets home. I got the CPS from O'Reillys. I drove the truck a couple of days ago and ran great.
Old Jul 14, 2009 | 11:05 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Make sure you are getting 10.5V while cranking. When you turn the key on, do you hear the fuel pump right under the front seat on the frame rail?
Welcme to FTE.
Old Jul 14, 2009 | 01:45 PM
BillyBob69's Avatar
BillyBob69
I had the same issue and a battery charger hooked up for about 10 minutes fired it right up. Crank but no fire. My neighbor stopped pver and pointed out that the ends of my battery cables at the batteries were swollen. Corroded badly inside the cable that it actually caused enough resistance to keep the injectors from firing.
Old Jul 14, 2009 | 02:12 PM
John52's Avatar
John52
Checked the cables, driver's side was spotless, passenger side had a little build up. Cleaned them both and made sure they were tight, still no go.
Old Jul 14, 2009 | 02:46 PM
miller_feed
Are you getting any clicking under the dash when you turn the key on?
Old Jul 14, 2009 | 03:05 PM
BillyBob69's Avatar
BillyBob69
With or without a booster?
Old Jul 14, 2009 | 03:54 PM
John52's Avatar
John52
Clicking coming from relay 301 and it is entirely stock. Got new batteries in it and cables are clean.
Old Jul 14, 2009 | 03:57 PM
BillyBob69's Avatar
BillyBob69
...Got new batteries in it and cables are clean.
Mine were too but it still needed a jump. These motors are pretty finicky...but if all that is covered.....Have you checked to bowl for fuel to make sure it is getting some? You can crack the drain valve a little to see if it is getting any. If you are then I would unplug the bowl heater and try again to see if that is causing you issues.
Old Jul 14, 2009 | 04:16 PM
superduty4x4's Avatar
superduty4x4
The relay chattering is usually due to bad connections at the batts or low voltage. Since you have checked both those things, i would start checking fuses. Billybob may be onto something with the fuel bowl heater- when it shorts out it blows the fuse that runs the PCM. No power to PCM = no start.
Old Jul 14, 2009 | 06:00 PM
F350-6's Avatar
F350-6
When did you get the new batteries? Have you had the batteries on a charger? If the batteries weren't too weak earlier today, they sure are by now.
Clicking relays is a voltage issue. This morning it turned over fine, not it's clicking. Charge the batteries. While your letting them charge up, check the other ends of the battery cables. The grounds, alternator connection, starter solenoid all need to be in good shape.
Also check for any blown fuses, make sure you got the CPS connector plugged back in good.
