9" Axle re-drilling???
Old Jul 14, 2009 | 10:31 AM
rockher_man's Avatar
rockher_man
Question 9" Axle re-drilling???
I started this here;
https://www.ford-trucks.com/forums/8...0-9-axles.html
...but have NOT had much luck...so...here we go...
Anyone had their axle flanges redreilled for a new bolt pattern???
Thinking about having my 5 X 51/2 axle flanges changed to matched my
new front IFS that are 5 X 4 1/2.
Is it neccessary to fill the old stud holes?
Do they need to be balanced afterwords?
Can the old stud holes just be "left open"??? (lightening holes?)
THANKS in advance...
Old Jul 14, 2009 | 10:50 AM
AXracer's Avatar
AXracer
Check the cost VS ordering a new set of axles from Moser or Strange (available from Jegs, Summit) The have street axles for ~ 300.00 a set already drilled for several different bolt patterns, choose your pattern and press in the studs. Change your mind? Knock the studs out and replace.
Old Jul 14, 2009 | 11:56 AM
LM14's Avatar
LM14
I had mine done at Quick Performance in Ames, Iowa. I took them the old axles and a new set of brake drums. They redrilled both to 4-1/2" bolt pattern. They drilled and tapped them and they use an Allen bolt for the stud. On mine, we didn't need to fill any of the original holes in the axle flange, some may/will need a hole filled depending on the design. With 2 new drums, drilling, removing original bearings and all new bearings, seals and retainers it ran me around $400 total. I chose to put new drums on so I would get the maximum time out of the operation. Mine has worked great so far. No problems and highly recommended.
Good luck,
SPark
Old Jul 14, 2009 | 06:52 PM
mixup's Avatar
mixup
I'm having my axles done right now on my 60 F100 from 5x5.5 to 5x4.5 by Dutchman Motorsports . Check the web site price list.
Old Jul 14, 2009 | 09:27 PM
MPH Racing's Avatar
MPH Racing
I do them all the time for customers stuff as well as the mosier axles in my truck they were 4 3/4 and I needed 4 1/2. Drilled the drums as well using the same setup.
I Set them up in the bridgeport and super spacer find the BC and start drilling not a big deal at all. Get a good bit and turn it slow crouding it so it cuts and does not rub or you will kill the bit in under 10 revs. Flanges are pretty hard so they are a little hard to drill if you have never done it but not too bad.
Mike
Old Jul 14, 2009 | 11:46 PM
BACAGrizz's Avatar
BACAGrizz
Never mind. Just read previous post.
Old Jul 15, 2009 | 11:18 AM
rockher_man
Talking Hhhmmmmmm......
...I started lookin' at Dutchman Motorsports in the FIRST place...
...thinkin' someone might want my original 28-spline axles
and 11" drums...they are in good shape...
Dutchman has a nice price on a complete set-up;
9" Ford type housing ends-Package=$370/pair
Includes; Axles, studs, bearings, & HD retainers
Your choice of bolt patterns & stud size
Seems fair to me...I already have a disc brake kit for the 9" ready
to install...
Old Jul 15, 2009 | 05:04 PM
mixup's Avatar
mixup
To redrill to 5x4.5 install new bearings and shipping $297 from Dutchman.
Old Jul 16, 2009 | 10:11 AM
rockher_man
Lightbulb $$$...
...I know...for another $75.00 bones...I get the whole package new!!!
I gonna spend more than that on beer tryin' to figure this out......
Old Jul 16, 2009 | 10:31 AM
AXracer's Avatar
AXracer
Or for the same money you could have gotten a brand new set of Moser axles with the flange predrilled with 3 different bolt patterns, and not had to tie the truck up waiting for the axles to be returned from the machinist, or worrying if the original axles were not already stressed and/or cracked.
Old Jul 16, 2009 | 12:17 PM
rockher_man
Question AX-le-mania...
Hey AX...not sure I'm followin' ya...but that's nuthin' new for me......
I was referring to the post by mixup...for an additional $75.00 bones...ya know?
Thats whats whats got me wondering about MY axles...they are 39 years old now...I'm sure they are a little bit "tired"...
Oh...I'm not worried about the "tie the truck up waiting" part...it's scattered ALL OVER lower Michigan......
PLEASE tell me more about this Moser-thing...did I miss "something" ?
I thought I had commited The Moser, Currie, FRPP, and Strange Catalogs to memory!!!
ThankX again brother......
Old Jul 16, 2009 | 03:48 PM
mixup's Avatar
mixup
Don't forget to add shipping on top of the $75 bones. Every penny counts and I can use that $75 somewhere else. For a regular driver I don't think the stock axles are going to be a problem even though they are old.
Old Jul 17, 2009 | 08:16 AM
rockher_man
Question ..........
...I hear ya......I already wore-out a quarter doin' the coin-toss thing...
I'm not really good at darts anymore......so that only leaves me with
an intellegent adult-type decision......
Figures...just my luck...
Of course every one I called so far says the same thing...just send 'em to Currie or Moser...
Anyone know about the spline-end of the axles...I don't mean changing the spline-count...
...but is there any type of re-hab that can be done?
...re-hab...startin' to sound like a cheap reality show on cable-TV...
artscott61
13
Apr 27, 2021 01:10 AM
mull3915
Jun 23, 2017 01:59 PM
patience
20
Oct 14, 2015 07:19 AM
awhtx
Large Truck
Mar 25, 2010 01:35 PM
orcal3056
Oct 3, 2009 03:47 PM
