A/C hoses
Old Jul 14, 2009 | 07:17 AM
Diesel_Brad's Avatar
Diesel_Brad
A/C hoses
where are you guys sourcing your new a/c hoses. I need to get the two from the evap core. And one from the pump to the condensor
Old Jul 14, 2009 | 09:24 AM
jsutton's Avatar
jsutton
I can't find them anywhere. Let me know if you do.
I just plan on buying the hoses and fittings online, then having them all crimped at an A/C shop locally.
EDIT: The only fitting I can't figure out what size it is, is the large fitting from the evaporator back to the compressor. I know it's a #12 hose, but not 100% positive if that is a #12 male o-ring fitting on that end of the hose.
Old Jul 14, 2009 | 04:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
If you have a Parker Store near you they can make up a set of A/C hoses fairly reasonable.
Josh
Old Jul 14, 2009 | 07:20 PM
bucks77ford's Avatar
bucks77ford
Aeroquip makes some good hose and fittings that lock together, but not cheap. This is a pretty good site.
http://www.nostalgicairparts.com/ac/ac-hose-kits-85.php
