A/C question
Old Jul 13, 2009 | 10:06 PM
BigJake34452's Avatar
BigJake34452
A/C question
hey guys, i know this has been discussed before BUT i cant get anything out of the search, so here goes. my a/c blows nice and cold and then all of a sudden usually in about 15 minutes, the compressor shuts off and blows hot air. i just had the a/c charged and would like to use the a/c for more than a few minutes at a time, i know there is a sensor but is that a common issue?
Old Jul 13, 2009 | 10:10 PM
SpringerPop's Avatar
SpringerPop
Clutch air gap.
Try this test:
https://www.ford-trucks.com/forums/5...ml#post4464164
Pop
Old Jul 14, 2009 | 08:16 AM
BigJake34452
thanks springer pop for the link i checked my gap and it was about .047 its very easy to do so i just took a washer out anyway but it put me below .025, maybe the clutch isnt that wore out yet.
Old Jul 14, 2009 | 09:20 AM
SpringerPop
Let us know what happens after fifteen minutes or so.
Remember, you MUST have SOME air gap. It has to be able to de-clutch or damage will occur.
Pop
Old Jul 14, 2009 | 11:45 AM
BigJake34452
o i just put the washer back in, ill just deal with it like it is for a while i guess, maybe the gap will get wider and i can take it back out? maybe?
Old Jul 14, 2009 | 12:13 PM
SpringerPop
Got a flat metal file and some patience?
Pop
Old Jul 14, 2009 | 01:04 PM
DieselBeast01's Avatar
DieselBeast01
There was only one washer in mine, so I just took it out. It blows extremely cold air now. I did it about 2 weeks ago, and I have had no problems yet.
Old Jul 14, 2009 | 01:55 PM
BigJake34452
SP, what are you saying i could file down, because i would like ice cold a/c but i wasnt comfortable with a gap of about .018".
Old Jul 14, 2009 | 02:13 PM
wla6518's Avatar
wla6518
Just did this over the weekend. I only had one shim in mine, too much airgap with it in, not enough with it out.
Dropped by Home Depot and picked up a 3 pack of 6mm washers (for maybe $1).
They are almost identical in size to the shim I had in there.
Grabbed my pliers and took them to a grinding wheel, with a little patience was able to get the airgap perfect. Clutch cycles perfectly now.
Old Jul 14, 2009 | 02:26 PM
BigJake34452
thanks alot man, ill stop by lowes tonight and pick up some 6mm washers and try it out for myself.
Old Jul 14, 2009 | 02:41 PM
wla6518's Avatar
wla6518
you bet, glad I could help out!
Old Aug 3, 2009 | 08:27 PM
danskool's Avatar
danskool
Go Bills !
According to this. .018" is ok.. Looks like .014"-.035"
Old Aug 3, 2009 | 10:01 PM
shark1979's Avatar
shark1979
My ac was acting funny last week, i checked the charge it was fine, but that sensor right by the compressor on the high side was loose and it keep taking my compressor out pulled the plug a part cleaned it, put it all back. been working fine for now. i think i will check the shim thing just for good measures.
mshargrave23
Sep 15, 2013 12:02 PM
rpbfixit
Jul 30, 2012 11:20 AM
MDSLIGHT
Jul 28, 2011 06:16 AM
oshoguno
Aug 21, 2005 10:04 PM
1993F150XL
Mar 13, 2003 10:49 PM
