Adjusting ITP OBA
Old Jul 13, 2009 | 08:34 PM
gasgrunt88's Avatar
gasgrunt88
Adjusting ITP OBA
I know a bunch of you guys out there have the ITP OBA. I think I need to adjust mine. Yesterday I got on it on my way in to work. My boost got up to 25 or higher and my CEL came on. The OBA is supposed to eliminate this correct? How do you determine the adjustments? Thanks gents.
Old Jul 13, 2009 | 08:41 PM
HKusp's Avatar
HKusp
It's almost NEVER the OBA setting. Don't adjust it. The parameters that the chip has set for the query for injection pressure for the HPOP are probably set too high for what your pump can put out. Jody fixed mine with a reburn. It sucks but that is probably what it is, not the OBA. Talk with Dennis at ITP, he will confirm what I said
Old Jul 13, 2009 | 08:55 PM
megawatt00's Avatar
megawatt00
Very well said Jason!!
Old Jul 13, 2009 | 10:30 PM
Strictly Diesel's Avatar
Strictly Diesel
FTE Sponsor
Agreed, DO NOT ADJUST THE OBA unless you have verified that the SES was turned on for an Overboost Code. There are other triggers for SES lights, including P1211 injection pressure codes...and some can appear to be boost related based on happening at or near 25psi when they in fact have nothing to do with boost pressure. ONLY adjust if you are postivie that you have a reoccuring overboost code (verified by clearing all codes and checking for new codes after triggering SES again).
Old Jul 14, 2009 | 12:32 AM
gasgrunt88's Avatar
gasgrunt88
Hmm ok. So if it is an injection pressure code, what does that mean? Don't lay the hammer down too hard until I can get bigger sticks?
Old Jul 14, 2009 | 07:17 AM
03_PSD's Avatar
03_PSD
Chris, my truck does the exact same thing CEL under heavy throtle.
Old Jul 14, 2009 | 09:12 AM
HKusp's Avatar
HKusp
I would call Jody or email him and tell him what you are experiencing. He may tell you he needs to re-burn the chip. I am pretty sure you can drive it like that, it's just a soft code telling you that things are not within the parameters set by that query. I don't think the truck alters anything or goes into a safe mode after throwing that code. The light should go off after a few minutes. I know it probably drives you crazy, it did me, but it won't hurt anything to drive it like that until you get the chip back to Jody.
Old Jul 14, 2009 | 10:07 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I am thinking about adjusting my OBA because with the AE hooked up, the pcm only sees 20# of boost. I wonder if it was seeing 22/23# of boost, something would change? Does anyone know if that would make a difference?
Old Jul 14, 2009 | 11:17 AM
gasgrunt88's Avatar
gasgrunt88
Yeah, nothing changed when the CEL came on. It is just kinda bothersome with that light on my dash. I'll have to shoot Jody an email.
Old Jul 16, 2009 | 12:49 AM
Strictly Diesel
FTE Sponsor
ICP codes are very very common with aftermarket programming. It just means that there is a difference between the ICP the program is asking for and what the pump is delivering. That difference exceeds a pre-set amount for a pre-set time and triggers the light. If the problem is mild, you won't notice anything but the light. If it's severe, you will notice the power drop off because the ICP is low enough that the atomization and fuel quantity are hurting as a result. It's not an "intentional" defuel like the overboost code triggers, simply the result of the lower ICP.
Doubtful there will be a noticeable difference, but it can't hurt to adjust it. At least with AE you can go backwards if you go too far.
Old Jul 16, 2009 | 01:32 AM
big poppa's Avatar
big poppa
My light comes on the dash also when I get on it. I had a ICP pressure code but can't remember which one, got it marked down in my code book out in my truck. I used my SC code reader. Come on up and we'll read your codes if you have any.. Chris, on a side note, did you get those plugs from the dealer yet?? I need mine back before the trip to RRE????
Old Jul 16, 2009 | 08:02 AM
miller_feed
Thanks Dennis. I think I will adjust it so the MAP sees 23psi and see what that does.
Old Jul 16, 2009 | 08:21 AM
Izzy351's Avatar
Izzy351
P1211 is the ICP uncontrollable code. It doesn't hurt anything -- just a function of hot tunes for split-shot injectors on stock oil.
I don't think it'll make a hill of beans difference...
Old Jul 16, 2009 | 10:38 AM
gasgrunt88's Avatar
gasgrunt88
Yeah Mike I got 'em. I will get them to you ASAP. Just PM me your address.
Old Jul 16, 2009 | 10:47 AM
big poppa's Avatar
big poppa
Good to hear, PM sent... Thanks Joe, had that code but haven't had it in a while even before my homemade OBA, seems to be working pretty good now...
herbiemin
Apr 7, 2016 01:08 PM
smoky_diesel
6.7L Power Stroke Diesel
Apr 5, 2016 07:12 PM
A/Ox4
May 9, 2015 09:45 PM
Krazee Matt
Apr 19, 2015 01:18 AM
