HELP! Brakes!
Old Jul 17, 2009 | 12:34 PM
  #46
74baja's Avatar
74baja
How easily do the brake pads need to slide back and forth in the clips? I got them in but they are pretty tight. They are tight enough that I am installing them in the slide pin bracket and putting that in the caliper. Is that okay?
Old Jul 17, 2009 | 08:29 PM
  #47
Kwikkordead's Avatar
Kwikkordead
You should be able to move them with your hand.
Fitting snugly is a good thing. If they are loose the brakes will rattle on every bump.
Old Jul 17, 2009 | 08:44 PM
  #48
74baja's Avatar
74baja
OK, so I got the worse side done. But when I moved to the other side, the caliper mount bolts were WAY too tight. Much tighter than the other side. I tried all day, all sorts of ways (I don't have air tools) to no avail. I do have a friend with impact tools, so I'll get to him next week. I guess when I got a new hub (wheel bearing) last summer, the mechanic did the final tightening with an impact wrench, which I have heard is a no-no. I guess this is why.
Old Jul 17, 2009 | 08:47 PM
  #49
Kwikkordead
Got a 1/2 inch drive breaker bar?
Put a pipe on the end of it to extend it and it will come loose.
Old Jul 17, 2009 | 09:32 PM
  #50
N V US Lawn Care's Avatar
N V US Lawn Care
I will refer you to my original post...it takes ALOT of A$$ to break that loose...i'm still tending to the strawberry i got from the wheel well...hehehehe...can somebody give an AAAWWWWEEEE....hahahahahahahaha
River19
Jun 27, 2011 08:30 PM
FTE/PARTS-GUY
13
Nov 6, 2008 02:12 PM
csangster
Sep 1, 2008 10:27 AM
DaMole
19
Mar 23, 2007 02:24 PM
truckfever
Mar 20, 2003 11:44 AM
