Paint
Old Jul 13, 2009 | 02:00 PM
Holiver31's Avatar
Holiver31
Paint
I know this should be in the Bodywork forum but replies there take forever. I'm having a problem while trying to buff away the haze that is left behind after wet-sanding. I used 2000 grit to sand the doors, when the doors are wet and you cant see the haze it looks AWESOME, but once it dries and I try to remove it with some rubbing compound I'm still having problems with the haze. Should I try a higher grit rubbing compound and see if I can bum a machine buffer?
Old Jul 13, 2009 | 02:37 PM
Witty73's Avatar
Witty73
You will definately need a buffer to do that kind of work. You will be at it a long time by hand. There is a process you need to follow, starting with a med cut and a cloth pad, then I like to use a foam pad and a light grit, followed by yet another foam pad and a machine glaze. The terms differ from product line to product line. I have had best luck with the 3m stuff and meguiars. Your best bet is to find an auto parts counter guy who knows his stuff and start asking questions.
Old Jul 13, 2009 | 03:30 PM
Recoil's Avatar
Recoil
Get a buffer with a terry cloth bonnet, and some turtle wax polishing compound. Have fun, and follow up with a good car wax.
