Need help finding a fuse.
Old Sep 21, 2012 | 05:24 PM
Gundown64's Avatar
Gundown64
I am trying to wire in some LED lights that I plan on placing above the driver and passenger floorboard so that when you open the door or turn on the interior lights, they will come on too. I am using a fuse tap rated for 2-10 amps. I know that fuse #24 is what I want, only problem is it is a 15A fuse. My main questions is are there any other fuses that work like fuse #24, coming on when doors are open (interior lights) and going off when the door is closed?
Quick question about the fuse tap as well. I am not an electrician by any means, so this may be a little silly, but the fuse tap is rated for 10A max, but is that just for the accessories (in my case the lights) that are added, meaning that amperage of the other fuse doesn't have to be under 10A or do both fuses have to be 10A or below? Obviously, I think that the latter is correct, otherwise I would have already had it hooked up to the 15A, #24 fuse, but I thought I'd still ask.
Thanks guys!
Old Sep 21, 2012 | 07:26 PM
gjnicholas's Avatar
gjnicholas
what ever you use on the tap needs to be 10 amp or less just tap to that fuse install an inline fuse and good to go pull the fuse out and find out which side is still hot and put the tap on that side
Old Sep 23, 2012 | 01:12 PM
Gundown64's Avatar
Gundown64
I don't know if I quite get what you are saying. The fuse tap has a spot for two fuses, the original and the accessory. Not sure if you are referring to that or not.
Old Sep 23, 2012 | 01:24 PM
shorebird's Avatar
shorebird
I would consider installing the tap on the supply side of the #24 fuse.
The amperage of the LEDs is probably under 5.
You will then have the 15 amp fuse continuing to protect the interior lights and install a 10amp or less fuse in the line to the new lights after the tap.
Old Sep 23, 2012 | 01:49 PM
Gundown64's Avatar
Gundown64
Ok, I think that is what I am wanting to know. The tap has a place for the original fuse and the one for the accessory. Although the tap itself is rated for 10amps, can I still plug in a 15A fuse for the original and then use a 5-10A fuse for the accessory. I am trying to know if the 10A rating is for the accessory AND the original or JUST the accessory.
Here is what I am using:
Old Sep 23, 2012 | 02:26 PM
tharepairguy's Avatar
tharepairguy
Have you considered using a relay to power the lights? You could use 2 fuse taps in theory. One like you have already found to use as the trigger for the relay when the doors open. Another fuse tap in an empty fuse location to power the relay. It's a bit more work and more bulky/pricy but keeps the rating down on the original circuit...
Old Sep 23, 2012 | 02:52 PM
shorebird's Avatar
shorebird
Use the original fuse in the open slot and hook up your new lights to the provided wire.
That type of tap does what I wrote about.
LED lights pull very low current so there is little additional draw on the original supply.
Old Sep 23, 2012 | 03:02 PM
shorebird's Avatar
shorebird
A bit of research led me to a description of this type of tap.
It states that the Cooper Bussmann/ATC fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit.
http://www.autozone.com/autozone/acc...ier=32414_0_0_
Old Sep 23, 2012 | 05:50 PM
Gundown64's Avatar
Gundown64
Cooper Bussmann/ATC fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHA-RP) | Fuse and Accessories | AutoZone.com
10A max on added circuit. So this means the other circuit can be OVER 10A? That is really all I need to know because if it is, then all I need to do is plug it into the fuse slot. If not, well, I'll have to find another way. Everything is wired and ready to go, I just need to plug in the tap.
Old Sep 23, 2012 | 07:41 PM
shorebird's Avatar
shorebird
The way I read it you are good to go with the 15A in the original circuit and the 10A in the additional line.
Old Sep 23, 2012 | 07:47 PM
Gundown64's Avatar
Gundown64
Ok, well I'll give it a shot. I guess the worst that can happen is a blown fuse?
Smoking Joe
Jan 15, 2018 08:26 PM
beachrods
May 10, 2010 11:36 AM
ncguy23
Electrical Systems/Wiring
Jul 27, 2007 03:33 PM
high ho silver
Dec 18, 2005 06:00 PM
Wmeyer
1983 - 2012 Ranger & B-Series
16
Jul 25, 2005 07:57 PM
