C4 Modulator Question
Old Jul 10, 2009 | 09:52 PM
Woodsman_30350's Avatar
Woodsman_30350
I have a C4 tranny on my 351W that I installed in my 1950 F-1. After four years I finally got it on the road and the tranny shifts fine but the shift points are way too high. I took in into a good tranny shop and the owner pointed out that I had a non-adjustable modulator (push-in) but it has a side entry port for the vacuum hose.
We want to change it to a adjustable modulator but the hose enters in the rear. Does anyone know where I could find the bracket that holds this type of modulator in place?
Old Jul 10, 2009 | 10:05 PM
Woodsman_30350
Sorry, wrong forum.
Old Jul 10, 2009 | 11:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since you have a 1950, I'd say you are not in the wrong forum.
Did you buy the engine and trans as a unit?
Most 351W's did not use the C4.
What did use a 351W/C4 combo was 1973/76 Torino's, not something you may be able to find today in a junkyard.
I looked for a modulator valve bracket in the parts catalog for this application, there isn't one listed.
On the left side of the case, near the servo cover is a tag that has the FoMoCo trans code on it...is it still there?
If so, post the code. I can then tell you what the trans is from, what mod valve it uses, and etc.
btw: Inside the modulator valve is a replaceable rod. There is more than one length, which varies the shift points.
Did the trans shop point that out?
HillBillyBuddha
Mar 13, 2014 04:25 PM
crazycd1
Feb 25, 2013 07:12 PM
JNM76
15
Apr 8, 2011 12:03 PM
Woodsman_30350
Jul 13, 2009 12:34 AM
JSPajak
Jun 11, 2007 04:13 PM
