hpop tsb?
Old Jul 10, 2009 | 07:45 PM
rob40cal's Avatar
rob40cal
hpop tsb?
I'm deleting my egr cooler and while i am in there, i thought i would update the HPOP fitting. i've read the TSB at the ford doctor web site and it lists two numbers one for the ford part and one for the international part. So i figured i would get from international, but their diagram does not show a support bracket like the fords? so should i use that one or get the ford? International says that is the latest design.
any comments?
Thanks
Old Jul 10, 2009 | 09:18 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
I may be wrong, but I'm not sure the VT365 is set up the same way...go for the FOMOCO part just to be safe.
Old Jul 10, 2009 | 11:44 PM
bismic's Avatar
bismic
The International part will work and, if it is the one-piece fitting, is the most recent part. The bracket is no longer the preferred upgrade. You just need to install the part properly.
Mahir Sa'id
Sep 12, 2015 01:03 PM
cope1972
Jul 27, 2014 06:34 AM
maxtruck00
Jun 9, 2014 09:29 PM
Nj shade
17
Apr 17, 2014 06:04 PM
BLADE35
Jan 2, 2014 08:18 PM
