Injector part number for international
Anyone have the international prat numbers for injectors? Or know where I can find them online? The dealer (international) couldn't look it up using ford part numbers and I looked online and couldn't find anyplace. Ford dealer wanted outrageous ammount for new injectors so hoping to get them right from international.
Ford part numbers:
53CZ* 9VE527*ARM. (AE code?)
53CZ*9VE527*BRM. (AD code?)
Found online that the ARM is AE (1) of this one for #8 injector, injector code and the BRM is AD (7) of them. Just want to confirm that is correct as well
Thanks in advance!
Ford part numbers:
Thanks in advance!
AD injectors: 1999-2002 Navistar T444E Fuel Injectors (Cylinder 1-7)
I don't see an IH p/n for the AE injector, but the Alliant p/n is here: 1999-2003 Ford E-Series, F-Series Fuel Injectors (Cylinder 8)
EDIT: The IH p/n for the AE seems to be 1833639C1 . . .
IH = International Harvester - they made the block, and Ford attached a bunch of stuff to make it a Powerstroke.
"Stick" with AD injectors. You don't want a piece of the AC game, unless you want more power and this:
I can't be certain, but it's most likely that the part number has been superceded a couple times. The IH dealer should be able find the numbers by looking up the injectors for a T444E engine of the same year as your truck, or with the engine serial number from the sticker on the left valve cover, too. Some of the parts guys don't like dealing with Ford truck customers for some reason.
Thanks for the info!!!
Think I found the numbers. As mentioned earlier, ford dealer wanted almost $400 each injector! International dealer a few months back gave me quite of $225 each. When went the other day to get them new parts guy was a real d*ck and played dumb with everything and kept insisting that I go to ford. Now with the part numbers and the serial number from motor will be going back on sat to get them!
Thanks again
Thanks again
The guy was an older guy and my vibe seemed that he either couldn't be bothered to look it up or didn't know how to in system. If was t such big money savings would not go back but the$$ is to much
Thanks again!
Just the #6 and #8 injectors came back as bad by dealer. Not having dealer do work, having local diesel mechanic do the work. My question is should I replace all while already in there or just the ones that are bad? Truck is an 03 f550 about 110,000 miles mason dump, so it is worked, bought used with around 70,000 on it so don't know how well first 70k were maintained.
Thanks again!
Not sure of the tests done to determine which injectors were bad. Was told 6&8 were sticking. Thought was glow plugs in begining.
Background of truck problems.... Did have the delaminating tank, cleaned out all debris in strainer in the tank, shop vac all diesel and debris from tank. Fuel constraint was so bad would lose power while driving, but was intermittent. That was spring last yr, once all cleaned no issues until fall. Original problems were hard to start in cold, brand new batteries, glow plugs working. Have to plug in to start in cooler weather, runs real rough when warming up.
I attached two YouTube videos of the sounds.
long crank, no start it cold
Running rough in cold when started (35-45degrees)
