custom intake
Old Jul 17, 2009 | 08:59 PM
Mat J's Avatar
Mat J
wreckinball, i read on here not to cut that plate because it stops water from getting into the engine. also that it isnt really a restriction. You could cut the soup bowl out but the performance for that is debatable just search.
I might try wrapping my intake my engine ran better with it over stock so insulating it should be better.
Old Jul 17, 2009 | 10:29 PM
dyoung14's Avatar
dyoung14
i thik i cut the plate your talking about i havent had no trouble and i drive in rain all the time with my ram-air intake
Old Jul 17, 2009 | 10:34 PM
fellro86's Avatar
fellro86
I used a piece of 4" exhaust pipe to make my inlet. I didn't do anything with the diverter in the air cleaner, but I did cut out the restriction in the bottom of my air cleaner. Most have a soup bowl, mine did not, it had the small hole in the bottom of the air cleaner base. I made the hole the same size as the intake, and that helped immensely, then the larger exhaust and intake didn't hurt anything either...
Dave, do you have a screen out in front of your intake? I put a perforated screen sheet a few inches in front of mine to help with large snow and bugs. Seems to work pretty good.
Old Jul 18, 2009 | 12:23 AM
wreckinball's Avatar
wreckinball
This is what i had, then just cut off the fins in front to reveal the screen behind it.
therigwelder
1997 - 2003 F150
Aug 3, 2016 11:08 AM
Glaser67
May 18, 2016 12:17 PM
jasindude1
Apr 16, 2016 04:24 AM
Pocket
32
Oct 16, 2009 06:20 PM
luvinfords
Oil & Lubrication
16
Jul 25, 2004 03:42 AM
