Question for NumberDummy about Trim
Old Jul 10, 2009 | 06:24 AM
es2rider's Avatar
es2rider
Hi, I am ready for paint and am getting ready to install new side trim on my 1965 F100.
My truck did not have this trim option and i want to get the location right. I'm a little nervous drilling holes after all this work.
I have a "1965 Ford truck body/interior assembly manual" and on the side trim page there is a note at the bottom:
NOTE: See ( C4TB-9927864-5-G-H ) for size and locating dimensions of holes to recieve retainers of body side moldings.
Is this part of a manual or just a sheet? Is it available?
Thanks, Doug
Old Jul 10, 2009 | 07:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks, Doug
Is this assembly manual published by FoMoCo. or it one of those books sold by the aftermarket parts suppliers?
Usually when Ford used instruction sheets, they have a form number on it, then the year it applies to, then numbers for that particular form, then a suffix.
Like this: FPS-651234-A. Form numbers (FPS = Ford Parts/Service) are listed on all of Ford's parts & service literature.
I have the Master Cross Reference Catalog for 1961/72's that lists the ID number, then the actual part number.
There are no numbers of C4TB-9947864-G or C4TB-9947865-H.
Those are 1964 numbers, so they cannot be any sort of instruction sheet that pertains to 1965/66 mouldings.
I have no clue what those numbers represent...except they are related to the bed only, as 99 is the Styleside pickup's body style.
Since carolina-classics.com sells the full set of mouldings, you might give them a call and ask if they have an instruction sheet: 800-598-4211.
Old Jul 10, 2009 | 11:06 AM
daveengelson's Avatar
daveengelson
Have the 'Body/Interior Assembly Manual' which has pic of location, number and type fastener for each piece of trim but does not mention the spacing. It makes reference to 'C4TB-9927864-5-G-H' "for size and location Dimension of holes to receive retainers of side molding". Good luck finding some obscure service repair, or maintainance sheet.
These pic are not out of the assembly manual:
http://i300.photobucket.com/albums/n...mfasteners.jpg
Marty in PA
25
Jun 18, 2012 12:54 PM
jwcorder
35
May 27, 2012 11:58 AM
Thunderbird7480
Jul 7, 2011 10:26 PM
es2rider
Mar 6, 2008 11:02 PM
dnmyoda
20
Mar 29, 2005 09:07 PM
