Rebuilt M5OD problem
Old Jul 9, 2009 | 08:35 PM
HappyJack's Avatar
HappyJack
I have a 94 Explorer Sport and had the tranny rebuilt two weeks ago. We just finished up the install tonight and it won't go in to 4th and it kicks out of overdrive when you let out the clutch. Is this a common problem with rebuilt M5OD's? Does it have to come back out to fix? I'll call the shop that rebuilt it tomorrow. Just need to know if I should bother and look for another shop or not.
Old Jul 10, 2009 | 11:57 AM
jim henderson's Avatar
jim henderson
Sounds like they screwed up on the synchros. Or maybe the shift linkage.
Linkage should just need adjustment. synchros probably need to have tranny dropped.
If it is a reputable shop, I would have them fix it at their cost. This problem should have been caught on their test drive before handing it back to you.
Most reputable shops have some warranty and will have no problem making this right.
Good Luck,
Jim Henderson
Old Jul 10, 2009 | 12:15 PM
HappyJack's Avatar
HappyJack
It was a carry out deal. I had pulled that M5OD 2 years ago when it had problems and replaced it with a C-5/4 and a doubler. So a lot had to be changed back. Crossmember, tunnel cover plate and shifters, driveshafts, ect..... I did call them this morning and they told me to drive it in. Just a few miles in town driving. It really did well in the gears I had. When I dropped it off the guy (owner maybe) said they would take care of it. I tried 4th several time on the way to the shop. Most of them just out of habbit. I didn't try overdrive. Thought maybe they'd pull the shifter and tunnel cover and see if they could go in through the top to fix it. I hope they can and get it back to me today.
Old Jul 14, 2009 | 09:18 AM
HappyJack's Avatar
HappyJack
Originally Posted by jim henderson
Sounds like they screwed up on the synchros. Linkage should just need adjustment. synchros probably need to have tranny dropped.Jim Henderson
Good call. I called them this morning and they said it will be ready today. There was a syncro problem in the back was the reason they gave.
dylani2003
Nov 17, 2011 07:09 PM
theedge900
Jul 24, 2007 11:37 PM
theedge900
Jul 9, 2007 03:03 PM
twillix5
1978 - 1996 Big Bronco
Feb 13, 2007 08:50 AM
dvhouse
Apr 5, 2004 06:26 PM
