Torqshift issues
Old Jul 9, 2009 | 06:34 PM
CLutchf250's Avatar
CLutchf250
Question Torqshift issues
I have a 2003 6.0 td, the tow haul light flashes after only 30 sec of driving. I understand there are only 3 gears 1-3-5 and each gear has an overdrive to give you the 2-4-6. 4th is only used when in tow haul. My truck shifts 1-3-5 only these three engage, reverse works fine. im getting two codes p0730 and p2701, the place that rebuilt my tranny has pulled it apart to check in side and they have found nothing wrong, I was hoping there was a sensor or wiring harness i could check, and then im thinking solenoid replacement. Im not a mechanic, i need advice, thanks.
Old Jul 9, 2009 | 08:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Instead of shotgunning random parts you probably would save a lot of money by paying someone who knows how to trouble shoot these transmissions to figure out exactly what's wrong.
Old Jul 9, 2009 | 09:15 PM
CLutchf250's Avatar
CLutchf250
i know i guess i was just hoping that it was an obvious fix. i hate paying for labor. and you never know when a business is trying to screw you.
Old Jul 10, 2009 | 07:51 AM
l-m tech's Avatar
l-m tech
sounds like you need a new coast clutch solinoid(p0730),and a new overdrive pressure solinoid(P2701).i also install new line pressure A solinoids when i build them because these transmissions develope a delayed reverse and forward engagment with high miles.just my 2 cents
Old Jul 10, 2009 | 04:55 PM
CLutchf250's Avatar
CLutchf250
2 cents
Thanks for the tips, thats going to be my next move. replace all the solinoids. I appreciate it.
Old Jul 10, 2009 | 06:32 PM
vloney's Avatar
vloney
Band, Clutch, Solenoid, Switch Application Chart (H)
NOTE: The PTO may operate in any gear including PARK and NEUTRAL, does not require OD OWC. The TCC may engage in PARK and NEUTRAL with PTO engaged.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle>Range Selector Lever Position</TH><TH vAlign=bottom align=middle>Gear</TH><TH vAlign=bottom align=middle>TCC Torque Converter (D)</TH><TH vAlign=bottom align=middle>OD OWC</TH><TH vAlign=bottom align=middle>L/R OWC</TH></TR><TR><TD vAlign=top align=middle>P</TD><TD vAlign=top align=middle>P</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>X</TD></TR><TR><TD vAlign=top align=middle>N</TD><TD vAlign=top align=middle>N</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>X</TD></TR><TR><TD vAlign=top align=middle>R</TD><TD vAlign=top align=middle>R</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>1</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>X</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>2</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>O/R</TD><TD vAlign=top align=middle>X</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>3</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>O/R</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>4 (b)</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>O/R</TD><TD vAlign=top align=middle>O/R</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>5</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>X</TD><TD vAlign=top align=middle>O/R</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>6</TD><TD vAlign=top align=middle>(a)</TD><TD vAlign=top align=middle>O/R</TD><TD vAlign=top align=middle>O/R</TD></TR></TBODY></TABLE>
(a) PCM Calibration Controlled
(b) Cold Strategy
O/R = Overrunning
LP = Low Pressure
LA = Low Current
X = Holding
(D) = Directly Proportional
Band, Clutch, Solenoid, Switch Application Chart (F)
NOTE: The pressure switches listed in the band, clutch, solenoid, switch application chart will not be applicable to all vehicle applications. Some vehicles will not have the pressure switches installed in the valve body.
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TH vAlign=bottom align=middle>Range Selector Lever Position</TH><TH vAlign=bottom align=middle>Gear</TH><TH vAlign=bottom align=middle>OD Clutch</TH><TH vAlign=bottom align=middle>PS-B (if equipped)</TH><TH vAlign=bottom align=middle>SSPC-B OD Clutch (D)</TH><TH vAlign=bottom align=middle>Int. Clutch</TH><TH vAlign=bottom align=middle>PS-C (if equipped)</TH><TH vAlign=bottom align=middle>SSPC-C Int. Clutch (D)</TH></TR><TR><TD vAlign=top align=middle>P</TD><TD vAlign=top align=middle>P</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>N</TD><TD vAlign=top align=middle>N</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>R</TD><TD vAlign=top align=middle>R</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>1</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>2</TD><TD vAlign=top align=middle>A</TD><TD vAlign=top align=middle>O</TD><TD vAlign=top align=middle>HP/HA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>3</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>A</TD><TD vAlign=top align=middle>O</TD><TD vAlign=top align=middle>HP/HA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>4 (b)</TD><TD vAlign=top align=middle>A</TD><TD vAlign=top align=middle>O</TD><TD vAlign=top align=middle>HP/HA</TD><TD vAlign=top align=middle>A</TD><TD vAlign=top align=middle>O</TD><TD vAlign=top align=middle>HP/HA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>5</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR><TR><TD vAlign=top align=middle>OD with Tow Haul ON</TD><TD vAlign=top align=middle>6</TD><TD vAlign=top align=middle>A</TD><TD vAlign=top align=middle>O</TD><TD vAlign=top align=middle>HP/HA</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>C</TD><TD vAlign=top align=middle>LP/LA</TD></TR></TBODY></TABLE>
(b) Cold Strategy
HP = High Pressure
LP = Low Pressure
HA = High Current
LA = Low Current
A = Applied
C = Closed
O = Open
(D) Directly Proportional
Old Jul 10, 2009 | 09:03 PM
CLutchf250's Avatar
CLutchf250
Question ???
I appreciate the effort but i have no idea what any of that means, i noticed on the first section that 2-4-6 gears use the od but i dont know what the rest means.
Old Dec 16, 2012 | 11:15 PM
dahoserman's Avatar
dahoserman
Is it normal when I put my selector in 1-3 gear to feel different on takeoff than in drive it seems to hesatate till it boosts then sling shots, but in drive it is responsive to the touch of the pedal. Is it designed that way for pulling and spooling the turbo or do I have a problem?
Old Dec 17, 2012 | 05:32 AM
Mark Kovalsky
It should be the same in drive as it is in 1. Both start in first gear. It is different in 2 and 3, with the lever in 2 the trans will be in second gear, not first. With the lever in 3 the trans will be in third gear, not first.
Old Dec 17, 2012 | 06:30 AM
jdw1's Avatar
jdw1
Mark
I have noticed this in fords, just wondering what the purpose of this is?
Thanks
Old Dec 17, 2012 | 07:44 AM
Mark Kovalsky
It allows better control of the transmission. If you want third gear, you get third gear, not first, second, and third gears. It is especially helpful in low traction situations.
Old Dec 17, 2012 | 07:55 AM
jdw1's Avatar
jdw1
Ok, Thanks
Old Dec 18, 2012 | 12:43 AM
dahoserman's Avatar
dahoserman
Thanks Mark first torqueshift tranny i've had and hard to grab the 2 speed aspect with it, glad it's normal with the 1 2 3 facts of what gear it's taking off in. I always start out in drive but once in awhile I might shift to 3rd by accident and that's when I notice the difference in takoff
Old Dec 18, 2012 | 08:08 AM
Mark Kovalsky
What is the two speed aspect of the TorqShift? I haven't heard of that.
Old Dec 18, 2012 | 05:42 PM
rattleNsmoke's Avatar
rattleNsmoke
I wanna 'borrow' this thread for a moment by asking why my transmission is delayed in shifting then shifts firmly when the OAT is cold (45 deg and below). Once the ECT warms up perhaps driving 1/2 mile the transmission shifts nice and smooth. Is that normal?
Mike
BeauF0RD
May 2, 2017 06:53 AM
Joseph D. Kendall
Jan 12, 2016 07:54 AM
F350SuperCab4x4
Oct 2, 2015 07:07 PM
1998F150XLT
Vehicles for Sale
Aug 11, 2015 08:24 AM
sherpa
2004 - 2008 F150
Nov 1, 2014 08:11 PM
