grill problem
Old Jul 9, 2009 | 05:08 PM
AZGUY's Avatar
AZGUY
grill problem
I went to put the grill on my 75 f250 and it does not fit. The area where the parking lights are run into the headlights. It looks like the parking lights should go where they are on the 78 and 79 models. Has anyone else had this problem? Was the previos owner a screw up and maybe put the wrong from clip on after an accident or something?
Old Jul 9, 2009 | 05:15 PM
75F350's Avatar
75F350
Only two grille shells available, the 73 to 77.5 and the 78 / 9 shell. Do you have any pics of what you are talking about?
Old Jul 9, 2009 | 06:37 PM
AZGUY's Avatar
AZGUY
I can try to take some but it will be a pain to hold the grill up there and take the photos since it won't stay. THe best way to descibe it is that when I go to put the shell on the top part of the shell covers the top 1/3 of the headlights. there is no gap where the parking lights should fit for the 75 grill shell the headlights are almost at the top, but there is a large gap on the bottom of the headlights that looks like where the parking lights should be on the 78-79 grill shells. does that make sense? I know they both fit on the trucks so I know I need a 78-79 grill but I can see why it is on a 1975 truck.
Old Jul 9, 2009 | 07:24 PM
montana_highboy's Avatar
montana_highboy
I'm not quite sure i'm following what's going on here, from your description it sounds like you need the 73-77 grille not the 78-79 grille.
Old Jul 9, 2009 | 07:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sounds like you are trying to put a 73-77 grille onto a 78-79 radiator support. no? I realize you are calling your truck a 75.
Josh
Old Jul 9, 2009 | 10:39 PM
bigun72's Avatar
bigun72
thats what i got out of it......
can u have someone else to hold it up so u can take a pic or tha other way around
Old Jul 10, 2009 | 12:12 AM
Bowtie_Schmowtie's Avatar
Bowtie_Schmowtie
I'll make this simple.
1. Does your truck have round or square headlights? If it has round headlights, then you need a '73-'77 grill shell like mine. If it has square headlights, then you need a '78-'79 grill shell like 75F350's.
2. If you have round headlights and a grill for square headlights, this obviously will not work, and vice versa.
3. Should you have round headlights and a '73-'77 grill shell and the shell does not fit, the radiator support has probably been replaced with an incorrect '78-'79 as Bullitt and Bigun said, and vice versa.
If you have all the right stuff and it still does not quite fit over the headlights, try dropping the lights down by loosening the four bolts behind each. I had to finagle mine a bit when I put my front end back together, but nevertheless it was just a matter of fine tuning, not incorrect parts.
The shell you have now- was it installed when you got the truck? I'll assume it wasn't.
Old Jul 10, 2009 | 12:51 AM
75F350's Avatar
75F350
73 to 77 grille shell:
78/9 shell:
Same 74 truck by the way.
Old Jul 10, 2009 | 01:03 AM
montana_highboy
Some '78's had round headlights.
Old Jul 10, 2009 | 01:28 AM
AZGUY's Avatar
AZGUY
here is the truck I have. it has the round headlights but they seem way too high for the 73-77 grill, by a few inches at least. I will try and get someone to help me take pictures with the grill up there tomorrow. The headlights are new and it didn't have a grill shell when I bought it. It's all from the previous owner.
https://www.ford-trucks.com/forums/8...w-project.html
Old Jul 10, 2009 | 01:38 AM
75F350's Avatar
75F350
OK, yeah, you have a problem. You have 78 "custom" trim level buckets on your truck. Notice how high the headlights are in relation to the "dent" when compared to the correct location here:
and here:
Now notice a rectangular headlight heigth, and you will see that you need a different grille shell, or some early headlight buckets.
The location of these rectangular ones are about the same as your round ones.
Yes, Im stuck, hey it happens......
Old Jul 10, 2009 | 05:09 AM
AZGUY's Avatar
AZGUY
so I need the 78 shell with the round headlights? How hard is it to change the buckets to a different position?
Old Jul 10, 2009 | 06:25 AM
ranger429's Avatar
ranger429
Drill new holes, simple as that.
Old Jul 10, 2009 | 06:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350: There are two different radiator core supports.
One for round headlamps (D3TZ16138B-1973/79), one for rectangular headlights (D8TZ16138A-1978/79).
What's the difference?
With rectangiular headlights, the core support is dished inwards behind the buckets to allow the seal beams to fit correctly.
The round seal beams are not as deep as the rectangular seal beams.
The grille shell used 1978/79 is the same with/without round headlamps. The difference is the headlight buckets, sealed beams and headlamp doors.
Either type will fit.
To install a 1978/79 grille into a 1973/77 requires the right & left grille brackets used on 1978/79's only.
Old Jul 10, 2009 | 09:05 AM
Recoil's Avatar
Recoil
To do it right you can either get a 73-77 core support, or get a 78/79 grille and use the round headlight bezel. I like the second option myself.
