height
Old Jan 2, 2003 | 02:15 PM
jamyboy's Avatar
jamyboy
height
Old Jan 2, 2003 | 05:52 PM
SNIPER 222's Avatar
SNIPER 222
height
i have a 2000 expy and i noticed that all the other expys
seem to sit higher than mine what gives?
i have the same tires as most of them
any ideas
Sniper
2000 Expy
5.4
dual ehaust
Old Jan 2, 2003 | 06:13 PM
98BIGBODY's Avatar
98BIGBODY
height
i know 4x4's sit higher than 4x2's.
Old Jan 3, 2003 | 06:43 AM
SNIPER 222's Avatar
SNIPER 222
height
i have a 4x4 so i dont know what the differance is
Old Jan 3, 2003 | 09:13 AM
buzzard's Avatar
buzzard
height
Weird!
Have you actually measured the other Expys or do you perceive that they are higher? Sometimes the mind can play tricks.
If the others are bone stock and you are bone stock, I can't think of any reasons why there would be a height difference unless LLS vs. non-LLS....just conjecture though.
My '00 4x4 sits higher than most because I've got 33's all the way around.
Old Jan 3, 2003 | 04:02 PM
marriedguy1's Avatar
marriedguy1
height
Does your Expy have the running boards? Did any of the others? That is about the only thing that might give it the look you are describing, at least that I can think of.
Old Jan 6, 2003 | 11:17 AM
Petrol's Avatar
Petrol
height
Perhaps your Expy is equipt with the optional load leveling AIR SUSPENSION system . . . if so it will sit about 1" lower then the model equipt with conventional springs as they need a bit more height to overcome 'spring sag' when loaded.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
