Leaking at the seams..
Old Jul 8, 2009 | 08:02 PM
greedy737's Avatar
greedy737
Is the over flow tank a ford item only?
Old Jul 8, 2009 | 08:23 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
Not sure but if it is parts guy ED would probably be your best bet for the cheapest one.
Old Jul 8, 2009 | 08:25 PM
12ozd's Avatar
12ozd
Yes, never seen it aftermarket.
Only other option would be a salvege yard.
Old Jul 8, 2009 | 08:43 PM
megawatt00's Avatar
megawatt00
I just searched around Ronnie and no luck I would give ed a shout.
Old Jul 8, 2009 | 08:44 PM
greedy737's Avatar
greedy737
Its been leaking slowly for a while! Better to replace it now, than have it blow out going up to the cabin this summer!! Just wondering if places like NAPA sells them?
Old Jul 8, 2009 | 08:45 PM
greedy737's Avatar
greedy737
Thanks Guys, I'll get in touch with him!!
Old Jul 8, 2009 | 08:49 PM
Orezona's Avatar
Orezona
A few months ago, a guy at Powerstrokeshop.com told me the over flow tanks are getting hard to find. A lot of broken mounting tabs. Didn't mention seam leaks. Makes sense I guess. Our trucks are getting older, the temps under the hood are high. Ever grab the tools mounted under there after driving around at full operating temp? He said it would be a good idea to find an extra and hold on to it.
Old Jul 8, 2009 | 09:17 PM
mueckster's Avatar
mueckster
I've already replaced mine twice due to a leak just above the seam in the front below the pressure cap. Both times it leaked from the same spot. I bought the degas bottles from Ford. Tried other sources, but no luck. Found only ones for cars. The last one has been holding up good, so far. It had a different number molded into it.
Old Jul 8, 2009 | 09:23 PM
greedy737's Avatar
greedy737
Thank again! Got to head out to work! 3rd shift... Going to order one from the FTE parts guy soon!!! real soon!
Old Jul 8, 2009 | 09:29 PM
big poppa's Avatar
big poppa
Good luck Ronnie, if it ain't one thing, its another. Roland, two tanks, wow, makes you wonder about these things..
Old Jul 8, 2009 | 09:44 PM
Bigcat350's Avatar
Bigcat350
Roland you must be cleaning it to hard.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
