Bronco II Ford Bronco II
Oil Pump replacement
Old Jul 8, 2009 | 06:25 PM
89_Brnko2!!'s Avatar
89_Brnko2!!
Hey guys a few weeks ago i was off roading my 90 bronco 2 when i started losing oil pressure and the top end start making a severe lifter taping noise,i stopped let it idle and the noise continued,decided to drive the truck home and during the entire trip home the ticking remained and varied by rpm,also the oil pressure gauge jumped around erradictly the entire trip.so i parked the truck assuming i had some trash in the bottom end,lost oil pressure and just wrecked the new heads i had put on it.I stepped back a week or so and just went over and started the truck and it ran just as amazing as it always have,no ticking no nothing,perfect oil pressure,everything.So now what to do?? i think im gonna buy a case of cheap oil and cheap filters,flush the s*** outta the motor,then change the oil pump and screen.Any suggestions?? also how difficult is it to get the pan of these things with the motor still in place,im assuming i gotta jack the motor up quite a bit for clearence......thanks
Old Jul 9, 2009 | 09:17 AM
89_Brnko2!!
Ive also came across a product called auto rx and ive done some research on multiple forums,and so far this seems to be the only product ive came across that actually cleans the engine without harming anything,so im thinking about running this product with some 15w40 diesel oil thats high detergent to flush it good,then change my pump and screen,,,what yall think????
Old Jul 10, 2009 | 01:08 PM
Help I M Stuck's Avatar
Help I M Stuck
change the oil/flush it..
then add new oil and leave out 1 quart..substitute that one quart for 1 quart of lucas ...you'll be good as new.
Old Jul 10, 2009 | 03:04 PM
Eddiec1564's Avatar
Eddiec1564
If you have put on new/rebuilt heads all ready and will be replacing the oil pump. I would also replace all bearings and rings if you pull the engine out. Probly be best to as bearing dammage may have happened.
Old Jul 21, 2009 | 04:05 PM
greenbullitt's Avatar
greenbullitt
The relie valve in the pump couldve hung..what happened prior? overrev anything like that?
Old Aug 1, 2009 | 09:24 PM
Djack04F150XL's Avatar
Djack04F150XL
How dirty was the top-end when you did the heads? If it had a lot of baked on deposits it could have stopped up the screen. You would need to pull and clean out the pan. Also inspect and/or replace the bottom end bearings and oil pump. If there is a lot of metal you may need to pull and rework the shortblock.
Old Sep 9, 2009 | 10:20 AM
baddmove's Avatar
baddmove
I think the question was this..
also how difficult is it to get the pan of these things with the motor still in place,im assuming i gotta jack the motor up quite a bit for clearance......thanks
I need to know this also..thanx
Old Sep 9, 2009 | 06:27 PM
Eddiec1564's Avatar
Eddiec1564
It probly won't happen as the firewall seam is almost right on top of the bellhousing. Probly only 2" clearance to work with, I doubt you will get the engine/tranny up high enough to pull the pan.
Ford_Eddie_Bauer
Mar 20, 2011 06:29 PM
TheTinian
1978 - 1996 Big Bronco
19
Aug 14, 2007 02:54 AM
kramer228
1997 - 2003 F150
Apr 21, 2004 09:08 AM
Slade901
17
Dec 24, 2003 11:33 PM
walkhaulsey
Mar 1, 2003 08:41 AM
