When I did mine I tied into the wire at the cruise control servo under the hood. This seemed to be the easiest to get to.
Cruise control? what for? I've got to tie one to parking brake (gnd) and one to reverse so the unit knows when I'm backing up. Guess I just don't understand what you would have tied to cruise control for, or does that have a reverse sense?
I think I found the sensor down on the tranny, which brings up another question.
Is there an easy place to tap into the Black / Pink striped wire for the reverse lights up near the dash? That seems easier than running a new wire up from the transmission at this point.
A lot of the navigation systems have you tie into the "speed sensor" on the tranny so the unit recieves the speed info from the vehicle. This is the wire I was talking about connecting at the cruise control for.
