Got some problems... Need help.
Old Aug 10, 2009 | 12:17 PM
strokersace's Avatar
strokersace
Originally Posted by superduty4x4
Is this the same Ryan that was giving me a hard time for considering doing the same thing?
No, I was actually in agreement with you on selling yours. Remember I was going to look for an OBS over here for you?!?!
This is why I started that thread over on FDP about the SD. I figure with all the aftermarket stuff out there today, you can make the inside of an OBS have just as many "creature comforts" as the SD's.
Old Aug 10, 2009 | 01:02 PM
superduty4x4's Avatar
superduty4x4
I'm just giving you a hard time... I know the feeling for sure. I'm still not sure if it's worth the trouble or not to sell my rig and start over with an OBS. Unlike you, I'd have to let my (very few compared to yours) mods go with the truck.
Old Aug 10, 2009 | 01:56 PM
strokersace
I know you were!! Yeah, if I can keep the main mods and put it mostly back to stock for not much $$ and get a decent price for it with the remaining mods, then I may just do it.
Old Jan 13, 2011 | 02:30 PM
strokersace
Update
Originally Posted by strokersace
Can't seem to figure them out.
I just bought a 1995 cc dually auto with 225K on it. Completely stock motor from air cleaner, squash pipe, cat, muffler, etc. Shifts just fine. He's checked all the fuses and they're good. No check engine or abs or brake lights on the dash.
It's currently at my folk's place as it was closer to them than me. So unfortunately I can't just run outside to try something. I'll have to relay the info onto my dad until I can get it later this month.
So what's going on:
1. The cruise doesn't work.
2. Only idles at 500 rpm which seems pretty low.
3. He says it's got a sound that he describes as "metal rubbing" when at idle. If he revs it up above 650 (which I think is the normal idle rpm) the noise goes away.
4. Yesterday when driving it around, when shifting from a drive gear to reverse, it would die. Unless he'd give it a little fuel to keep the revs up, then it'd go into reverse fine. From park to reverse it's fine.
5. This morning when he started it up, it started right away and ran strong for 30 seconds to a minute then acted like it stumbled/bogged down and died. He restarted and it died right away. Restarted again and he pressed on the pedal lightly for the first minute or so, then it was fine. Never tried to die again and then set and idled fine.
Any and all ideas would be great. Don't know if any or all are related but I'm just trying to figure out what I've got on my hands.
Thanks
Updating this for anyone having similar issues doing a search.
The cruise didn't work because the sensor at the front of the mater cylinder was bad. It's the cruise control sensor that Ford has put the recall on.
The low idle rpm was just from the computer in it. I've since changed computers and it idles higher.
The rest of the issues (dying, metal rubbing sound, etc) were all related to the torque converter. It was on it's way out the door. Replaced it and no issues of the sort.
Old Jan 13, 2011 | 02:54 PM
superduty4x4
Slow day at the office Ryan?
Old Jan 13, 2011 | 03:07 PM
jeremy2008's Avatar
jeremy2008
I know what your are talking about by noise my truck dose the same an it is coming form the bell housing mine is because my torq converter nuts are striped an my torq converter moves different from the flywheel. These e40d make some of the most strange noise i will never own one again they are a piece of chit an coast to much to build so they are strong.
hillbilly469
1997 - 2003 F150
Dec 3, 2015 09:11 PM
4x4 Nut
2004 - 2008 F150
Apr 16, 2015 02:29 PM
McStein
1983 - 2012 Ranger & B-Series
Mar 18, 2015 09:26 AM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
paddler
Apr 6, 2009 03:04 PM
