HEI didtributor in 400
Old Jul 7, 2009 | 11:30 AM
ltlvt's Avatar
ltlvt
Question HEI didtributor in 400
I'm thinking about buying one of the proformance HEI distributors for my 400 in my 81 F-350 truck. Has anyone used this distributor? The engine is stock with the 2150 carb. I'm thinking the distributor comes with a steel gear. Is this gear compatable with the stock camshaft? Thanks
Old Jul 7, 2009 | 12:03 PM
ibleedblue1385's Avatar
ibleedblue1385
Friend of mine has one on his 400, dropped in and ran with out any problems. And yes it comes with a steel gear, compatable with a stock camshaft.
Old Jul 7, 2009 | 06:36 PM
73XAFalcon's Avatar
73XAFalcon
I'm guessing you are talking about Performance Distributor and their DUI distributors? If you are looking at the Procomp copycat crap off ebay then good luck. I'm running a DUI and love it. Simple to hook up and they set it up for your engine....the Procomp uses a generic curve and module.
Old Jul 7, 2009 | 09:43 PM
ltlvt's Avatar
ltlvt
This is the distributor that I am talking about.
http://summitracing.com/parts/PRO-66980B/?image=large
Old Jul 8, 2009 | 04:48 AM
wyazel1's Avatar
wyazel1
Im running a mallory HEI in my new 400 and it works great but i will tell ya one thing you better have a pretty small diameter air cleaner or it wont clear. I put a 2" spacer under my aircleaner pretty simple fix.
Old Jul 8, 2009 | 12:30 PM
73XAFalcon's Avatar
73XAFalcon
Ok, never used them so I can't and won't recommend. But I have used Performance Distributors DUI. They are the guys that created the market. Here's a link to theirs:
http://www.performancedistributors.c...stributors.htm
Old Jul 8, 2009 | 06:11 PM
grclark351's Avatar
grclark351
a steel gear is NOT compatible with a stock flat tappet cam. the summit listing states that the gear IS steel...
Gear Material Steel
Notes Distributor gear is compatible with factory roller cam. Distributor shaft diameter is 0.530 in.
now if that's an error or not i don't know? but 66980R states that it comes with an iron gear, appropriate for a stock flat tappet cam
http://summitracing.com/parts/PRO-66980R/
Old Aug 6, 2009 | 03:07 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
www.PerformanceDistributors.com
hail destroyer
27
Jun 16, 2018 09:46 AM
sand1
Sep 4, 2016 07:24 PM
Mitchapalooza
Feb 24, 2016 03:38 PM
tomwerm
19
Mar 24, 2015 12:13 PM
'66f100boy
Jul 9, 2008 07:32 AM
