Sponsored by: Auxito
5.4l engine swap for lightning
Old Jul 6, 2009 | 05:15 PM
WEFITE4U's Avatar
WEFITE4U
Some of you know that my wife killed her truck several months ago. It has been sitting in the driveway waiting to be saved ever since. I may have found a complete lightning engine, supercharger, computer, wiring harness, and transmission from the same year(2002) as my wifes truck.
My questions are, will the lightning engine work with my current manual transmission, and is there any other reason why this swap wont work?
My thinking is that if i am replacing the engine anyway, i may as well get the most out of it.
Thanks
Old Jul 6, 2009 | 05:55 PM
nflfreak43's Avatar
nflfreak43
why do this swap. what happened to your wifes truck? just blew the engine or what?
Old Jul 6, 2009 | 06:08 PM
WEFITE4U's Avatar
WEFITE4U
https://www.ford-trucks.com/forums/8...home-help.html
Her engine seized several months ago. I have to swap it out so...
Old Jul 6, 2009 | 06:22 PM
nflfreak43's Avatar
nflfreak43
did you ever figure out the final issue with the motor. it might be something like a spun bearing. and is the lightning drivetrain for free or how much? it might be more for your liking to spring for a complete rebuild of the original motor and do a few performance upgrades. you could easily with just like 2 grand get way more out of the 5.4 than the Lightning 5.4.
Old Jul 6, 2009 | 06:26 PM
WEFITE4U's Avatar
WEFITE4U
for the price i can get everything from the lightning , and the sale of the lightning transmission, and the current parts that will be replaced i will be spending less then what it will cost to do a rebuild.
Old Jul 6, 2009 | 06:28 PM
nflfreak43's Avatar
nflfreak43
ok. see i didnt know if you was having to spend a ton or not. and as far as the manual tranny working with the L i think it will. im pretty sure it will. maybe someone else with more experience on these new trucks could come along and assure the answer.
Old Jul 6, 2009 | 06:33 PM
WEFITE4U's Avatar
WEFITE4U
Well, i have no idea why i typed manual...her truck has an automatic transmission.(stupid mistake) My main concern is the extra power eating the AUTOMATIC transmission. I would think that everything else would be pretty straight forward...
Old Jul 6, 2009 | 07:53 PM
galaxie641's Avatar
galaxie641
If you have the 4R100 it will be fine, the 4R70 will have a drastically reduced life behind that engine. You'll also need the L fuel pump BTW.
Old Jul 6, 2009 | 08:10 PM
WEFITE4U's Avatar
WEFITE4U
Thanks, that is what i was looking for. The fuel pump and intercoller are about the only things that i will have to go looking for.
Old Jul 6, 2009 | 09:58 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
The 4r70w will hold up just fine, there are quite a few people on this site that supercharged there trucks and dont have any issues, but sometimes trannys go, but i dont think its to often. And how you drive makes a huge difference. If your constantly abusing it, of course its going to go early.
Old Jul 6, 2009 | 10:41 PM
ebxgsxr's Avatar
ebxgsxr
i thought there was a kit that some site was selling with all the required components for a lightning swap (other than the motor, trans, ecm) like all the pullies, brackets, etc. and that kit alone was like $1800. ill try to find where i was reading about it.
Old Jul 7, 2009 | 08:25 AM
BURNSTOUGHFORD
One problem is that the 4r70w will be incompatible with the Lightning ECM, the lightning only came with the 4r100, and the two tranmissions, wont work with each others ecms, due to different hardware to control them.
So you will have to have the transmission out of the lightning if you use the ecm that goes with it.
Old Jul 7, 2009 | 11:16 AM
WEFITE4U's Avatar
WEFITE4U
And if i use that transmission i lose 4 wheel drive. That really sucks.
Old Jul 8, 2009 | 12:25 AM
BURNSTOUGHFORD
Well not really, i think if you get another tail shaft from a 4x4 4r100 you would be fine, i know there are plenty of 4x4 4r100's out there, just less common. All f-250 LD and F-7700's had them.
Old Jul 9, 2009 | 07:19 PM
WEFITE4U's Avatar
WEFITE4U
Thanks for the info. I will start looking for another transmission.
jsmith428
1997 - 2003 F150
Jul 22, 2016 10:46 PM
95centurion
Apr 8, 2016 03:39 PM
rockrig4x4
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 11, 2015 03:03 AM
hugo_7
Engine Swaps
May 9, 2014 09:26 AM
mac06gt
62
Jan 15, 2012 11:42 AM
