front end alignment
Old Jul 5, 2009 | 09:48 PM
89f15o's Avatar
89f15o
front end alignment
i have a 1989 f150 2 wheel drive it was recently in an accident and the top of the wheels bow in i have taken it to a shop and they said they didnt have the tools to do it is it possible to adjust caster and camber on my truck
Old Jul 5, 2009 | 09:51 PM
guitarnik's Avatar
guitarnik
yes, you need a cam set (camber adjustment bushings) if a shop says they cant do it tak eit somewhere else or do it yourself. if they say it cant be done i wouldnt trust them.
trvcampbe's Avatar
trvcampbe
No,you cant do it your self (Im assuming you dont have the correct equipment).Try another shop or the stealership..
Old Jul 5, 2009 | 09:54 PM
trvcampbe's Avatar
trvcampbe
Sorry,i read it wrong..Yes it is adjustable..
Old Jul 5, 2009 | 10:05 PM
89f15o's Avatar
89f15o
i took it to mr.tire they said a body shops most likley to have it i mean it was in an accident i dont think any things bent i read some where that the upper ball joint is adjustable ?
Old Jul 5, 2009 | 10:09 PM
89f15o's Avatar
89f15o
<a href="http://imagecloset.com/view25/de6f517bfdee0e9b6df4c002107a48ed/P1011461%20%28Medium%29.JPG"><img src="http://imagecloset.com/25/de6f517bfdee0e9b6df4c002107a48ed/P1011461%20%28Medium%29_thumb.gif" border="0" /></a>
Old Jul 5, 2009 | 10:10 PM
89f15o's Avatar
89f15o
thats what they look like hard to see but tops of wheels bow in
Old Jul 5, 2009 | 10:12 PM
89f15o's Avatar
89f15o
<a href="http://imagecloset.com/view25/5ff3b95db238acb8f6c039e690c9727b/P1011446%20%28Medium%29%20%28Large%29.JPG"><img src="http://imagecloset.com/25/5ff3b95db238acb8f6c039e690c9727b/P1011446%20%28Medium%29%20%28Large%29_thumb.gif" border="0" /></a>
Old Jul 5, 2009 | 10:15 PM
trvcampbe's Avatar
trvcampbe
Yes they offer problem solver joints to bring the camber back out..But im not sure if thats all you need..If it is leaning excessivly i would have it check for bent or brocken front end components..Good Luck
Old Jul 5, 2009 | 10:17 PM
89f15o's Avatar
89f15o
so a good shop could correct that
Old Jul 5, 2009 | 10:35 PM
trvcampbe's Avatar
trvcampbe
Yes,they should be able to..
Old Jul 6, 2009 | 12:14 AM
Jermafenser's Avatar
Jermafenser
You need to take it to a GOOD body shop and have them check the whole front end out. Who knows what got shifted?
Old Jul 6, 2009 | 07:22 AM
fordpatriot's Avatar
fordpatriot
If the wheel took a hit it is possible to bend a ball joint. Seen it many times in auto accidents before. Weak springs also allow the top of the wheels to tip in, IE negative camber. If you are unfamiliar with front end alignment, take it to a known good shop that has the experience to do a proper evaluation of the entire front end.
Old Jul 6, 2009 | 06:46 PM
thedoctor's Avatar
thedoctor
I took off my camper shell and now the alignment is slightly off. I know that the alignment on a TTB is dependent on the load being carried by the truck. Is it possible to make minor alignment adjustments due to how much the truck is loaded up on the TTB suspension?
Old Jul 6, 2009 | 07:46 PM
Jasonboy's Avatar
Jasonboy
Like The others have said bring it to a shop to have the front end looked over. If everything is okay then they can adjust the camber for you using new adjustment bushings. Installing the bushings are not that hard if you have a puller and a good set of tools. Problem is without an alignment machine you have no
idea how far to turn them for the adjustment.
