88 Rear Antilock code 2: 'Open Isolate Circuit'
Old Jul 5, 2009 | 07:14 PM
karljay's Avatar
karljay
I have an 88 F350 w/rear antilock. The dash light is on, has been for a long time. The code reads 2 (one short flash, one long flash).
The books says this is an 'Open isolate circuit'. Does that mean that one of the wires is not connected? Is the 'isolate circuit' a sub part of the brake system and is that where the short / break is?
Any help would be great, thanks KarlJay.
Old Jul 5, 2009 | 09:04 PM
trvcampbe's Avatar
trvcampbe
If that is the correct code,there is three parts to it 2a 2b 2c.It can be a long diagnosis process.Go to this web site and you can find many different pin point test and much more for your truck..It will cost you 17 dollars for a year but well worth it to the DIYer..Good Luck.. http://www.alldatadiy.com/
Old Jul 5, 2009 | 10:33 PM
karljay's Avatar
karljay
OK, looks like it's also know as:
2 Open Isolate circuit (In RABS Isolate/Dump valve)
So has anyone delt with this before?
Does it need to be reset or something?
I know it has a bleader valve on it. is there a special way to bleed these brakes?
Old Jul 5, 2009 | 10:49 PM
bmf316's Avatar
bmf316
the abs system in these trucks is a primitave design, even when it is working it doesn't really "work", just pull the bulb out if the "rear antilock" light annoys you.
Old Jul 5, 2009 | 11:02 PM
trvcampbe's Avatar
trvcampbe
These trucks are light in the rear end,the Brakes can lock up easy in the rain thats why it has the RABS..If you pull up your truck on the web site above it will give you many pin point test to narrow it down.. The culprit is usually the Hydraulic Unit or Rear Speed Sensor..I have replaced tons of them over the years..The hydraulic unit is about $140 and the speed sensor is $20..But i would spend the $17 on Alldata first to diagnose it.
Old Jul 6, 2009 | 05:01 AM
Lazy K's Avatar
Lazy K
The bleeding sequence is RR, LR, RABS module, RF, LF. However from the code it sounds like the RABS module is faulty. I take it you have the sinking pedal?
Old Jul 6, 2009 | 11:29 PM
karljay's Avatar
karljay
YEA, the pedal did sink... is there a way to just bypass the anti lock, because it sounds like something I can live without. I don't have anti lock on anything else, but I'm concerned about lockups. I was thinking of a bias valve that would give more pressure to the front brakes, the adjustable ones are only about $50.
Old Jul 7, 2009 | 04:21 AM
Lazy K's Avatar
Lazy K
There is an easy way to bypass the dunp circuit in the RABS module. You will see a large hex bung on the front of the module, unscrew it against the spring pressure and remove the spring (no fluid will come out). Replace the bung. Pump the pedal a few times to fill the chamber and the sinking pedal should be gone. You can restore the module to original again simply by replacing the spring. I drove mine for four years with the spring out and it was great not to have the pedal sink at lights.
Old Jul 7, 2009 | 06:07 AM
jr32560's Avatar
jr32560
pretty neat trick-I've heard of guys just removing it all together and putting in a short section of brake line before-luckily I haven't had a problem with mine over the years
(crosses fingers)
Old Jul 7, 2009 | 07:05 AM
Lazy K's Avatar
Lazy K
(crosses fingers)
Thank you. That only works if the problem is with the dump solenoid, the bypass pipe would be needed if the problem was something else such as fluid not returning from the rear brakes.
Old Jul 9, 2009 | 11:45 AM
stangbanger's Avatar
stangbanger
how do this illumination bulb lol?
My brake light is also on though ?
Old Jul 9, 2009 | 12:31 PM
Lazy K's Avatar
Lazy K
Both lights on together is usually due to low brake fluid level, bad wiring connection at the master cylinder or a defective fluid level sensor.
Old Apr 8, 2012 | 09:55 AM
HH1492's Avatar
HH1492
I was researching a problem with my 91 F150 RABS. "Open Dump Circuit". Found a link to a site called ALLDATA DIY that was recommended about 3 years ago in a post. Is it worthwhile?
Old Apr 9, 2012 | 05:09 AM
Lazy K's Avatar
Lazy K
Well, if you go to autozone.com and register with the repair section (free) you can get free access to a lot of alldata.
However for open dump valve circuit probably the solenoid valve inside the RABS Hydraulic Control Module is bad or the wiring pigtail to it is bad.
You will get plenty of info on the system if you google kelsey-hayes rabs or kelsey-hayes rwal. Also good info at raybestos.com in the training section.
Old Apr 14, 2012 | 03:47 PM
HH1492's Avatar
HH1492
Thanks for the info Lazy K
karljay
29
Jan 24, 2017 08:29 AM
Bret Smith
Jul 5, 2015 01:25 AM
BltFordTough
Oct 30, 2010 05:18 PM
crazypaw
1983 - 2012 Ranger & B-Series
38
Apr 2, 2008 09:08 AM
