Sponsored by: Auxito
Idle Problem
Old Jul 5, 2009 | 04:15 PM
ddp52's Avatar
ddp52
Idle Problem
I recently cleaned the Throttle Body because of a EGR code and replaced the PVC hose that was leaking because of a Oxygen Sensor Code. I have been fighting a bad idle issue when the engine warm up and you come to a stop and even when you are taking off . I have replaced the Plugs, COPS, swapped out the IAC, EVR and Vapor Management Valve and cleaned the MAF. Today I had my wife drive an stop when it started the idle issue and found that when I pull the vauum hose off of the EGR it stops idling badly. It appears that maybe something is activated when it doesn't need to be. Any ideas? No CEL codes are being posted for this problem.
Old Jul 5, 2009 | 04:25 PM
ddp52's Avatar
ddp52
This is a 01 with 4.6l v8.
roller_steve
Mar 18, 2025 11:57 AM
rwdfan
Jul 29, 2018 06:38 PM
areyou4real
Aerostar
26
Nov 9, 2015 05:19 PM
Alaska Explorer
Nov 17, 2013 09:28 AM
winger27
Escape & Escape Hybrid
Oct 23, 2010 08:07 AM
