Turbo "Swoosh" noise vs. Drone noise
I recently did the 6637 mod and I have heard of the increase in the swoosh noise from the turbo.... I dont think I am hearing this noise. I do hear the drone from intake but that is all.
Can anyone explain to me what this swoosh noise is that I'm not hearing?
The noise appears to be credited to the open filter being less noise restrictive than the factory box. There is also a pressure differential aspect to this as the modified intake is less restrictive and when the exhaust pressure wheel abruptly changes speed (auto trans shifting under load) you can get some swooshing or stuttering. Sometimes called stall or surge (not interchangable), these conditions can be fatal or no problem depending on who you talk to and what exactly the sound is. More informed members have a better grasp than I do on this.
Doesn't sound like you are hearing either so.... no worries.
You have an automatic rrrrrrrrrrrrrrright? Not sure you will hear it with a stick.
With a stick it's about the same thing. I have a 6 spd and when I go to shift I get the sneeze effect
1st gear: some turbo, sometimes a sneeze if I'm really on it but I don't stay in first very long
2nd gear: turbo is on, shifting causes a cool sneeze
3rd gear: Turbo is singing like an angle, shifting makes me think that the clutch releases pepper into the intake (j/k)
4th gear: SCREAM TURBO SCREAM and upon shifting..... A-CHU!
5th? eh, it's all turbo baby, well except that stinking ticking noise I have not rid myself of because my passenger side up pipe is leaking a little bit.
swoosh1958
12-13-2020 04:45 PM
01 powerstroke
15
03-03-2011 10:27 AM
