Sponsored by: Kumho
Need Help with this one.
Old Jul 5, 2009 | 02:40 PM
pacrewchief's Avatar
pacrewchief
I am working on a 1995 F-350 4WD Dually Diesel. I replaced all of the brake hoses and steel lines, new calipers, pads, rear drums, shoes and wheel cylinders and a new master cylinder. Bled the brakes and got the air out. When you start the motor the brake pedal goes right to the floor. Motor not running works as it should, motor running pedal goes right to the floor. I have already changed the master for another new one. The problem is in the front wheel circuit. I isolated the brake fluid to the wheels by pinching off the hoses and then released them one at a time while my assistant (my wife) was putting pressure on the pedal. When the rear wheels were released the pedal held strong as you would expect. When I released either front wheel the pedal went to the floor. As a note this was done with the engine running. So now I know the "problem" is in the front wheel circuit. I am confused....it just does not make sense??? Appreciate your help.
Old Jul 6, 2009 | 05:20 AM
Lazy K's Avatar
Lazy K
Your description of brakes with engine off and engine running is classic for air in the system, I would bleed them again, closing the bleed screws each time before the pedal is released. However there are other rare possibilities, one is bulging flexi hoses when full brake pressure is applied, another is caliper piston seal roll. This "roll" can occur when the piston drags the seal forward when the brakes are applied and then the seal drags the piston back too far each time.
However I still think it is air.
Old Jul 6, 2009 | 08:30 AM
bghnkinf250's Avatar
bghnkinf250
Did you bleed the ABS parts of the system? I forget the name of them, but they need to be specifically bled.
Old Jul 6, 2009 | 04:28 PM
andym's Avatar
andym
ABS is only on the rear on this truck.
pacrewchief, Did you bench bleed the master cylinder?
Old Jul 6, 2009 | 04:39 PM
pacrewchief
Yes, the master cylinder was bench bled and the RABS valve was missing when the truck got here. I agree with LAZY K I am still thinking air is in the system.
Old Jul 6, 2009 | 04:59 PM
andym's Avatar
andym
Sounds like air to me too.
clouden
May 2, 2011 12:05 AM
77_150_460
Jan 25, 2010 06:14 PM
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
So-Cal Sancho
Offroad & 4x4
Apr 17, 2009 04:01 PM
78F150RangerXLT
Mar 22, 2009 01:56 PM
