6.4 Smoking?
last winter a guy that i work with and myself started making our own biodiesel and i know the 6.4 will run a 75% ULSD 25% biodiesel mix because we did it last winter when diesel was high priced. i am too scared to try a stronger mix or anything else. we were making biodiesel for 90 cents per gallon.
Well I took the truck in and they said that my downpipe is split in half!!!! that's why it has been smoking from under the cab when it goes into regen. So then they took a look at the transfer case since I am having a problem when I put it in 4x4 it makes a loud clunking sound, they told me my transfer case is SHOT and needs to be replaced, here is the great part, I bought the truck used with 57,000 mi on it, so they said it would be a good idea to purcase the extended warrenty to cover the drivetrain, well I just found out that what I bought does not cover the transfer case!!!!! it is just for the motor, so I am out $2,500.00 bucks, I am not very happy with Ford right now since I purcased this truck because Ford bought back my 03 due to problems with the engine and drivetrain. Now I feel like it is starting all over again! I hope that after this I don't have any issues, but the truck only has 66,000 mi on it and the friggin transfer case and downpipe are already being replaced, makes you wonder if Ford is even worth it.
Sorry to hear about your troubles c dogg. At least your 6.4 is working right and you found out what the issue was. About the transfer case, can you recall anything that may have caused it to fail? You may have gotten bitten by the previous owner or the dealership on that. Could have been bad when you bought it.
sonofafordman,
Welcome to FTE!
You may need the latest PCM flash. While the truck is in regen it should display the message "cleaning exhaust filter" the entire time it is in regen mode. Regens vary but every 200 miles is quite common.
I do not lose power while my truck is in regen only fuel mileage.
Welcome to FTE!
