Mobil One and XT-5-DM compatibility
Hey guys,
It's been awhile since I've dealt with the transmission fluid change. I am short on time as I'm leaving on vacation so took the Excursion into the dealer to have the coolant and trans flushed. I told the service manager that I had synthetic in there and was concerned that they flush it, he said they use synthetic. Well, I was just looking at my bill and it looks like they put 7 units (I assume that's 7 quarts) of "XT-5-DM" fluid in which means they probably just drained the pan, I know it holds about 18 quarts and need about 22 to do a good flush. The receipt also didn't indicate that they charged for a filter either. I did have them replace my external trans filter while they were at it so that's something. From what I understand the fluid they used is dino, not syn. Is that compatible with the Mobile One Dexron/ Mercon I had in there or will it cause damage. I would at least expect them to replace all of the fluid rather than the 7 quarts. I am headed through the mountains with a 9-10k lb. TT and want no problems.
Thanks,
Steve
Thanks,
Steve
I just did a little searching on XT-5-DM. It's Mercon V like our tanny's need and they buy it by the 55 gal drum by that product number. I couldn't find anything on whether it was syn or dino, sorry. I am wondering if the 7 means gallons not quarts, if that is the case then they used 28 quarts which is really high.
Sorry I couldn't help you, hopefully one of the guru's will be along shortly!
When are you heading to the moutains?
Strike 3
Thanks,
Steve
Thanks,
Steve
Yes, that's my plan, but in the meantime, are the fluids compatible? I need to do some driving before I take it back. He originally gave me a quote of $125 which sounds like about the right price for a complete flush. They only charged $70. I need to ask about the coolant flush also. The bill says they added 1 gallon of coolant, then the charge is for 3 gallons. Should be 4 gallons of concentrate. I've always believed that the only way to get it right is to do it yourself and I always have. Just out of time. Oh yeah, they charged me $200 to replace the t-stat and housing that I supplied. Since they were draining the coolant anyway, should be a few minute job to remove the 3 bolts and replace. Stealership for sure.
Methodical_1
1997-2006 Expedition & Navigator
08-06-2010 08:10 PM
98SurplusExpy
1999 to 2016 Super Duty
22
04-03-2010 07:55 AM
