F450 Running Problems
Old Jul 1, 2009 | 11:48 PM
blue66tang95f150's Avatar
blue66tang95f150
My cousin has a F450 with the 7.3 in it. He uses it for work pulling around his skid steer and as a service truck. It does not run right. It will start fine and run fine while he pulls out onto the road, but about 30 seconds later it loses all power and wont rev up. It will start missing and idling very rough. The motor will also get noisy too. Like the injectors are getting loud because they are running out of fuel. Where should he start. He changed fuel filter, and drained the bowl, and checked the connectors going into the valve covers. Any help would be great thanks.
Please no acronyms please, I don't know what they are.
Old Jul 2, 2009 | 01:07 AM
Nick 99's Avatar
Nick 99
Do you have access to code reader?
Old Jul 2, 2009 | 01:37 AM
Kwikkordead's Avatar
Kwikkordead
99% chance of the fuel pickup screens being clogged.
Removing the fuel tank on a 450 is a 30 minute job using a tranny jack.
Drop the tank, pull out the fuel pickup, and clean the screens inside the white housing.
Old Jul 2, 2009 | 04:33 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Kwik & Nick have your best advice, and Kwik has an F550 and is a (hell of a) mechanic. Start there, especially with getting the codes read. Unfortunately with our trucks, the readers at Auto Zone can't access many of the functions and don't do a thorough job. There might be someone local to your friend that can fully read the codes if you let us know your location.
Also, learning acronyms will help you as you hang out more on this board, and hanging out here will definitely help save you money.... well, CAN help. PMS will be the first. Powerstroke Modding Syndrome, meaning that you'll start making mods to improve the truck, and not be able to stop!
Here is a link with a TON of acronyms, but like anything else, the more you use them, the more proficient you will become.
https://www.ford-trucks.com/forums/1...finitions.html
Welcome to FTE!!
Old Jul 2, 2009 | 05:31 AM
Visseroth's Avatar
Visseroth
Sounds accurate to me. The last time I had symptoms like that I had gas in my diesel, well more gas then diesel in the tank. 30 gallons of gas, 8 gallons of diesel and my truck would not move above 25mph, sounded horrible, like it was about to break something, wouldn't rev, just plain sounded broke. I realized later it was a gas problem, pumped all the fuel out, refilled with diesel and WAM! all better. There was a positive side to it though. I cleaned my fuel lines out and found out that my wife's van can get 30mpg with a little diesel in it
bottom line: Sounds like a fuel pickup/feed problem as long as it does NOT have gas in the tank. Take a sniff of the fuel tank with the gas cap off and see if it smells like gas, if not then time to drop the tank and while your in there you might as well do some mods.
Old Jul 2, 2009 | 09:42 AM
blue66tang95f150
That would make sense he is on his third inline fuel pump since he has had it, about a year. That may be why they are burning up, its working too hard to pull fuel from the tank. Or maybe even the pump in the tank is bad. Hmm. That would be nice if that was it. Next he wants to do some mods. His truck weighs 13k and he regularly weighs mid 20ks pulling trailers. It just doesn't have the power he wants. Any advice to start with. I am from the 95-97 section so I dont know much about the newer ones other than they have the same basic motor.
Old Jul 2, 2009 | 10:51 AM
Kwikkordead
Do what I did to my truck.
Your engine will have all the fuel it will ever need.
https://www.ford-trucks.com/forums/4...-the-tank.html
I pull 24k with ease. Only have to shift down once on 6% grades.
Old Jul 2, 2009 | 10:55 AM
Kwikkordead
You'll end up with fuel volume like this.
http://good-times.webshots.com/video...ost=good-times
Old Jul 2, 2009 | 02:54 PM
Visseroth's Avatar
Visseroth
Well, get a hold of Clay (RiffRaff Performance) and he'll set you up with quite a few of the things that you need to make these babies run better but here's a list I started.......
https://www.ford-trucks.com/forums/8...ml#post7572843
Old Jul 11, 2009 | 01:16 PM
blue66tang95f150
Well it wasnt thd fuel system at all. It was the injectors. He took it in to a diesel shop and had them test it. I guess the injectors are leaking bad, the computer is saying there is a high persentage of oil leaking threw the injectors. Its kinda crazy to me, the truck only has 120k on it! Seems like most guys get AT LEAST 200k out of injectors. Heck my 95 has 193k on it and it runs great. So now he is going to have the injectors rebuilt into stage 1s i think. Anybody know a good place to get injectors. This is a work truck and is heavy, and pulls heavy stuff, so they need to be good ones. I still have a hard time believeing the injectors went bad at 120 k though. What do you guys think?
Old Jul 11, 2009 | 03:25 PM
schlepprock250's Avatar
schlepprock250
Oh boy...a "diesel shop" told him it was injectors,...I would try to get a second opinion...not trying to say nothing bad about the shop he knows,but you know how it is....Just my .02 worth
Old Jul 11, 2009 | 04:09 PM
Visseroth's Avatar
Visseroth
It seems they always blame the injectors
Old Jul 11, 2009 | 06:08 PM
Kwikkordead
That won't fix it, IMO.
All eight injectors taking a dump at the same time?
I got a bridge for sale too.
Old Jul 11, 2009 | 06:52 PM
bkcowboss's Avatar
bkcowboss
pull the tank....i was told injectors also....pulled the tank and did the hutch mod....injectors lasted another 40,000 miles then they got traded in on stage 1s...
Old Jul 11, 2009 | 10:05 PM
Visseroth's Avatar
Visseroth
I wonder if the fuel pump is not sustaining pressure as it should. I wonder if it starts to tire when it gets warmed up.
If it was me I'd go through the whole fuel system, do the tank mods, pull the pump and if possible test it for an extended period of time with a flow meter on it, clean the fuel bowl, check the lines and/or blow them out from the bowl to the block, anything and as much that you can think of. Heck if you have the money replace the fuel system with some upgrades, that'll eliminate most the problems.
