A/C Compressor Problem/Noise
Old Jul 1, 2009 | 06:31 PM
bwoldschool65's Avatar
bwoldschool65
My A/C compressor makes a clattering noise when engaged but cools a little when on....could use a charge ....it sat for over a year. Do i need a new compressor...can it be rebuilt? Thanks for any help.
Old Jul 1, 2009 | 07:56 PM
subford's Avatar
subford
The noise may stop after a while, the noise may be oil and it may even out soon.
On the other hand if the noise is coming from the front it mat be a bad clutch or open diode.
Old Jul 1, 2009 | 09:18 PM
bwoldschool65
Well, when I take the belt off the pully turns fine till you engage the clutch then it has a catch about once every turn. But it seem to be locked up until I took the belt off and turned it by hand to loosen it up. I'm hoping that since it sat for a while it just needs a good charge and with fresh oil.
Old Jul 2, 2009 | 06:19 AM
subford's Avatar
subford
Sounds like the half ***** have ate into the piston and are jamming on the wobble plate.
Time for a new compressor.
MCDavis
2004 - 2008 F150
Jun 29, 2011 11:43 AM
xplorerboy
Aug 15, 2008 09:20 PM
Trial and Error
Jun 14, 2005 04:51 AM
RADIOMAN
Modular V10 (6.8l)
Jul 7, 2003 01:50 PM
