air bag light.
Old Jul 1, 2009 | 08:21 AM
tjc transport's Avatar
tjc transport
i ain't rite
air bag light.
yesterday afternoon, the air bag light cane on in my 02. the truck has 154k miles on it, and alot of that was in town driving by a landscaper..
ya think the clockspring is the reason??
Old Jul 1, 2009 | 08:25 AM
F350-6's Avatar
F350-6
Check the code Tom. When you first turn on the key, the lamp will flash a code. Something linke 2 flashes pause 7 flashes before it stays on (code 27). That's your LFC (lamp fault code).
Old Jul 1, 2009 | 09:15 AM
tjc transport
i ain't rite
4-7 code Chris
Old Jul 1, 2009 | 10:17 AM
12ozd's Avatar
12ozd
47 = passenger pretensioner circuit resistance high.
Check the wiring and connector to the pass.side pretensioner.
(might as well do both sides)
IIRC there was a tsb about this a few years ago.
Old Jul 1, 2009 | 02:02 PM
tjc transport
i ain't rite
you mean the passenger seat seat belt??
Old Jul 1, 2009 | 02:13 PM
duck fan's Avatar
duck fan
Because racetruck
There is a wiring harness under the seat that gets kicked loose sometimes. IIRC its yellow. Check all the connections under the seat. Should set you right up.
Old Jul 1, 2009 | 02:14 PM
12ozd's Avatar
12ozd
Yes sir.
(sorry I should have put that in)
Old Jul 1, 2009 | 02:38 PM
tjc transport
i ain't rite
well, the plug in plugged in, and i ran the seat belt in and out a few times, but the light is still on.
Old Jul 1, 2009 | 03:04 PM
duck fan's Avatar
duck fan
Because racetruck
Has anything gotten spilled under there? Try cleaning the contacts on the wiring harness.
Old Jul 1, 2009 | 03:14 PM
tjc transport
i ain't rite
nah. the only thing i can think of is that i had 3 people in the truck yesterday, and the light came on about 5 minutes into the ride. i think one of the guys might have messed up the plug, or the seatbelt.
Old Jul 1, 2009 | 03:17 PM
duck fan's Avatar
duck fan
Because racetruck
Yeah the code is for high resistance in the electrical circuit. You may just need the light reset after checking the harness. Jim is the electrical guy. Maybe he can chime in on what to look for.
Old Jul 1, 2009 | 06:34 PM
F350-6's Avatar
F350-6
I thought the passenger airbag circuit was under the dash? I was thinking plugs under the passenger seat were power or heated seats. I don't believe I have a plug under my passenger seat.
You can try checking this plug Tom, but make sure you disconnect both batteries for 15 minutes and have the key out of the ignition before playing with any airbag stuff. Pinch the sides of the glove box in and let the door down all the way. Then see if you can find this plug.
Old Jul 1, 2009 | 07:16 PM
12ozd's Avatar
12ozd
Disconnect the plug,check the wires and plug.
The TSB calls for wrapping the wires against the harness,and tapeing.
Take a good look at the wiring and the plug.
thunderbolt427
1997 - 2003 F150
Jul 9, 2007 09:45 PM
mvlr5000
Aerostar
Nov 14, 2003 02:08 AM
RYVVY34
Jul 21, 2003 03:04 PM
jopey
1978 - 1996 Big Bronco
Feb 9, 2003 05:07 PM
