Air Bag Light
Old May 19, 2003 | 10:57 AM
RYVVY34's Avatar
RYVVY34
Unhappy Air Bag Light
MY AIR BAG LIGHT STAYS ON OR FLASHES PERIODICALLY.IS THIS A EASY FIX???
Old May 19, 2003 | 06:00 PM
dennyge's Avatar
dennyge
Air Bag Light
I had this problem on my 96 as well. Some of the fine members here told me to count the flashes as it will indicate the error code. There will be two sets of flashes, the first indicating the first digit of the error code, and the second set for the second digit. Once the flashing has cycled, there will be about a 6 second pause until it will flash the code again. This will continue for a number of cycles until the warning light just stays on. If you then post the error code here, you will find that there are numerous people here, including CobraXP--the moderator, who can help you to decipher the information.
Good luck. Mine still flashes every time with a code 41 primarily because I'm too lazy to fix it.
Old May 19, 2003 | 11:29 PM
WillieTD's Avatar
WillieTD
Air Bag Light
Mine is 3 sets of 2 short flashes, then it stays on as long as the X is on. How would I decipher that?
Old May 20, 2003 | 10:07 AM
RYVVY34's Avatar
RYVVY34
Air Bag Light
IS THEIR A REMEDY YOU USE THAT I CAN USE UNTIL I GET TO THE DEALER.DEALER SAYS MY WARRANTY WIL NOT COVER BECAUSE I DID NOT PICK THE PREMIUM PLUS PACKAGE,I JUST HAVE THE PLUS WITH 100 DOLLAR DEDUCTIBLE???
Old May 20, 2003 | 06:12 PM
reberhardt's Avatar
reberhardt
Air Bag Light
An LFC (Lamp Flash Code) of 32 means that the driver's side air-bag module circuit has high resistance or is open. If it were mine, I would check to be sure the driver's side air-bag is plugged in and that none of the fuses are blown in the in-car fuse box and in the under-hood fuse box.
Old May 20, 2003 | 06:14 PM
reberhardt's Avatar
reberhardt
Air Bag Light
Sorry, misread it, I thought you said your LFC was 32, when now that I looked at it again, I think you are saying it is 22. In this case, a 22 means that safing sensor output circuit shorted to battery voltage. Sorry, I don't really know where to go with this one since I'm not sure what the safing sensor is.
Old May 21, 2003 | 06:49 AM
dennyge's Avatar
dennyge
Air Bag Light
I knew these guys wouldn't let you down, RYVVY. Hey Reberhardt, while you're at it, could you tell me what the flashing 41 means. Someone deciphered for me before, but I've long since forgotten.
Thanks!
Old May 21, 2003 | 05:56 PM
WillieTD's Avatar
WillieTD
Air Bag Light
Thanks, reberhardt. I'll check it out. At least it gives me an idea of where to start.
Old May 22, 2003 | 01:42 AM
reberhardt's Avatar
reberhardt
Air Bag Light
LFC 41 means RH air bag sensor feed/return circuit open
Old Jul 19, 2003 | 11:28 PM
fordrver's Avatar
fordrver
Air Bag Light
Anyone familure with 47 code? I've checked around, but all the code pages I could find only read 41 through 44. However, I did notice all of these have to do with crash sensors. Does anyone know if 47 is also a crash sensor code and, if so, the more exact meaning of it?
Thanks.
-Ford RV-er
Old Jul 20, 2003 | 11:54 AM
Racerguy's Avatar
Racerguy
Air Bag Light
Hi fordrver and welcome to FTE
What year and model of vehicle?
When do you get the 47? Are you positive it's a 47?
Old Jul 20, 2003 | 10:40 PM
fordrver's Avatar
fordrver
Air Bag Light
yup, went out and double checked it and it is 47. It is a 98 V10 E super duty chassis. Thanks for your help (and the welcome)
Old Jul 20, 2003 | 11:18 PM
Racerguy's Avatar
Racerguy
Air Bag Light
There's the problem....it's a van
The code 47 means Passenger Belt and Buckle Assembly Pretensioner Circuit Resistance Out of Range.
I would start by looking at the wiring to the passenger's seat belt buckle. You'll quite likely find it has been pulled apart by someone kicking under the seat or something like that.
Old Jul 21, 2003 | 02:22 PM
fordrver's Avatar
fordrver
Air Bag Light
thanks for your help. glad it was something simple.
Old Jul 21, 2003 | 03:04 PM
Racerguy's Avatar
Racerguy
Air Bag Light
So what did you find?
Derrick Coffman
Escape & Escape Hybrid
Aug 18, 2015 09:22 PM
Stroker 6.0 fan
15
Oct 26, 2013 09:57 AM
Bob V
Feb 14, 2009 10:45 PM
nmcjg44
1983 - 2012 Ranger & B-Series
Apr 15, 2007 10:56 AM
Scrapiron66
Jan 12, 2006 11:48 PM
