hard 2 start
Old Jun 30, 2009 | 06:23 PM
Tomazz30's Avatar
Tomazz30
hard 2 start
my truck is starting like its january and i didnt plug it in
Old Jun 30, 2009 | 06:24 PM
Tomazz30's Avatar
Tomazz30
could someone give me some advice about my 99 F250 7.3L deisel
Old Jun 30, 2009 | 06:25 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
we need more details. do you get any smoke when it starts, any rough idling? was it fine before and it just happen?
what year is the truck?
and does it spin slow ? or it just wont start and it spins freely?
starter#1
snakedoc's Avatar
snakedoc
Need more info, how is it starting. is it long and dose it smoke when started?
Old Jun 30, 2009 | 06:26 PM
PETE'S_6.0PSD
BTW plug it in and see how it starts
#2 Glow Plug Relay might be a suspect too.
#3 how old is the oil in the truck?
Old Jun 30, 2009 | 06:48 PM
zx250's Avatar
zx250
Of the next Riffraff East
Sounds like you may be due for some new batteries.
Old Jun 30, 2009 | 07:10 PM
Tomazz30's Avatar
Tomazz30
there is no smoke and it turns over slow
Tomazz30's Avatar
Tomazz30
the batteris are both new
Old Jun 30, 2009 | 07:11 PM
Tomazz30's Avatar
Tomazz30
oil is new
Tomazz30's Avatar
Tomazz30
truck has 216k on it
Old Jun 30, 2009 | 07:12 PM
PETE'S_6.0PSD
starter or batteries. check the voltage on batteries while cranking( BTW how old are they) and it should be minimum 10.5v, if you getting less time for batt, if its around that or more - time for new starter. did you check all the batt cables and connections ? make sure they tight and not corroded...
Old Jun 30, 2009 | 07:13 PM
zx250's Avatar
zx250
I don't think glow plugs would be an issue this time of year. Check all of your connections for tightness and corrosion. You may have a starter going out. Did this happen at once or has it been getting worse.
Old Jun 30, 2009 | 07:14 PM
PETE'S_6.0PSD
i had the same problem with weak starts, replace batts , and turned out to be a starter. so if you batts are new , my money is on the bad starter...
Old Jun 30, 2009 | 07:15 PM
PETE'S_6.0PSD
post #3
Old Jun 30, 2009 | 07:18 PM
Tomazz30's Avatar
Tomazz30
sorry im back
