Computer code location
Old Jun 30, 2009 | 06:19 PM
61 uni's Avatar
61 uni
I need to find my computer code to get my chip reprogramed. I read somewhere you can see it with a mirror and flashlight, but I couldn't see anything but plastic. I don't want to pull the computer just to get the code.
Old Jun 30, 2009 | 06:28 PM
superduty4x4's Avatar
superduty4x4
Just pull it, it only takes a few minutes and is easier than screwing around with a mirror. But if you are so inclined, between the PCM and the driver's side fender.
Old Jun 30, 2009 | 06:30 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well sometimes you have to do just that
might be on DS door jamb
if its not there you can just take those 2 bolts that are holding the PCM plastic, slide it off the PCM and just pull it gently towards the pedals and you should be able to see it with the flashlite.
and taking PCM out is about 15 min from start to the end when you put it back in.
Old Jun 30, 2009 | 08:24 PM
61 uni's Avatar
61 uni
is the pcm code the only thing jody needs
Old Jun 30, 2009 | 08:28 PM
PETE'S_6.0PSD
there is a PCM code and trans code.
lets say
PMT2
DPC422
you need both sets of codes....above is just an example.
Old Jun 30, 2009 | 08:34 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Just send him your VIN, he can get the PCM code from that.
Old Jun 30, 2009 | 09:04 PM
big poppa's Avatar
big poppa
Thats what I did...^^^^^
Old Jul 1, 2009 | 09:23 AM
superduty4x4
What if the PCM has been swapped in the past?
Old Jul 1, 2009 | 09:28 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If the chip came from Jody, he should know what it is. You can also look at your receipt from when you bought it and the code will be on it.
Disreguard this if you bought the chip from someone else.
vcmadsen
Computer Chips & Tuners
Apr 17, 2008 01:07 AM
joker2
Oct 5, 2007 08:38 PM
scout72
Aug 31, 2004 02:58 PM
ghambley
1997 - 2003 F150
Sep 3, 2002 07:55 AM
rhetor
Jul 5, 2002 12:35 PM
